philips: Different dB value to Voltage -Range Switch
This article refers to the model: Breitband-Millivoltmeter GM6012 (Philips; Eindhoven (tubes international!); Miniwatt)
12.Oct.16 20:13
942
Note the different value dB to Voltage on the range switch.
I Have a GM6012 with Zero dB at 1V range (-60dB at 1mV)
Skale Zero-dB is possitioned at the 300 range (70,7)
dB skale range is then -10..+20dB
and
GM6012/03 with Zero dB at 3V range (-70dB at 1mV)
Skale Zero-dB is possitioned at the 100 range (70,7)
dB skale range is then -20...+10dB
The different pictures are already in the model-page, only not mentioned /03
and the difference.
Regards,
Maurice Hamm
