France: Unknown Manufacturer ALTA
24.Dec.05 04:07
Georg Richter (D)
Articles: 916
Count of Thanks: 8
Georg Richter
Merry Christmas, dear all.
I am wondering about the "ALTA" sign on a really old
5-tuber which I assume it is made in France:
Maybe a very small manufacturer?
Homebrew with parts from "ALTER"?
(All resistors and capacitors are "ALTER")
The Philips tubes may not be related to this model, remaining
are two A416 and one B403. They also are marked ONYX,
the A416's additionally "GDEIS":
The coils are perfect manufactured, even if the
wires are wound on old newspapers and the mechanical
application looks way handicrafted.
The Volt-meter is from "Sigogne & Cie.", 0 to 40V.
The circuit itself seems to be changed sometimes ;-)
Please take a look at the attached pictures, any hints are
highly appreciated.
Kind Regards,
Georg Attachments:
Philips ONYX GDEIZ ?
24.Dec.05 10:57
Werner Braun (D)
Articles: 224
Count of Thanks: 12
Werner Braun
PHILIPS radio tubes seemed to be quiet common in French radio sets of the late 1920s.
I wondered about the "ONYX" and "GDEIZ" stamps as well.
http://www.radiomuseum.org/forum/a410n.html
Does anyone know about their meaning?
Best regards and merry christmas to all , Werner.
GDER
25.Dec.05 03:25
Georg Richter (D)
Articles: 916
Count of Thanks: 9
Georg Richter
Hi all,
not GDEIS, not GDEIZ, but GEDR (Jugendstil!). Excuse the French note
from http://www.mev.fr/histoire.htm , you must scroll down some meters ...
"Ce papier de soie entourait une lampe dans sa boite.
Si la France était à la traine des Etats-Unis sur le plan technique, elle était par contre bien en avance pour Taxer ! Le sigle GDER atteste que le constructeur du tube a bien payé la première taxe de l'audiovisuel française !"
Enjoy the translation of Altavista Babelfish:
"This tissue paper surrounded a lamp in its limps. If France were with the traine of the United States on the technical level, it was on the other hand well advances Taxer with it! Initials GDER attest that the manufacturer of the tube paid well the first tax of audio-visual the Frenchwoman!"
Thanks to Jean Claude Pigeon the small manufacturer ALTA seems to be identified, but the receiver is not yet to find anywhere.
The parts marked "ALTER" are from an other manufacturer.
The newspapers which are used as core to make the coils are refering to 1875 ;-)
Regarding ONYX, actual announcements in WWW
"Philips cathode tube production site in ... group), and Onyx in France, a subsidiary of the Veolia Environnement group. ..."
seems to be an answer.
So far today.
Kind Regards
GR
France Unknown manufacturer
26.Dec.05 20:55
Jean Beseme (F)
Articles: 9
Count of Thanks: 7
Jean Beseme
ALTER was a French components manufacturer who was still active in the 70's under the brand "MCB-Veritable Alter" as a producer of potentiometers (carbon and wirewound).
As for Veolia, it's a subsidiary of Vivendi-Environnement, specialising in the garbage collection and disposal !
See "Radios von gestern", page 223 for GDER
27.Dec.05 06:07
Officer
Articles: 5742
Count of Thanks: 13
Werner Braun (German) wrote an eMail to me, explaining what GDER means and I had to wonder why he writes to me something which I have described in "Radios von gestern" 16 years ago ...
I should not be involved personally with such single matters - as the example shows ... I found the reason by typing GDER into the SEARCH - this thread ... My hours are already far too long ... I don't get through if I don't get up early ...
In "the bible of the German radiocollecotrs", as it is often called, you "naturally" find also a short history about French radio tube manufacturers etc. The Expression is explained on page 223 above right and details given to it.
27.Dec.05 19:48
Werner Braun (D)
Articles: 224
Count of Thanks: 8
Werner Braun
I beg Your pardon...
First I sent the email by mistake to the "Moderator" instead of the "Author"
Second I saw the "GDEIZ" several times in reality and I always understood it as "GDEIZ".
I'd never made any link to  "GDER" at all.
If I had known what to look for, I would have done so.
Mfg Werner
