grundig: 3055WF/3D; High plate voltage on EABC80
? grundig: 3055WF/3D; High plate voltage on EABC80
EABC80 plate voltage
Hi,
after a look at the schematic, the grid voltage is only defined from the 10MEG resistor. If this resistor is open, the grid is to negative, and the plate is to high. If you measure at the grid, possibly you can't see the right value.
For test, short the 10MEG and watch the plate voltage.
Another check is, if the cathode contact to ground is ok, perhaps there is a weak contact in the socket.
Good Luck
Georg
Thanks Georg.
Grid bias resistor of EAB80 is around ~11Mohms and I am reading -0.350V from the grid. Looking at the chracteristhics of EABC80, this should give ~0.5 mA plate current with 50V plate voltage, which is close to current value in the schematics (0.4 mA).
There is something not clear in the schematics, probably I am missing something: Plate voltage of EABC80 should be :
V_plate_EABC80 = V_G2_EL84 - I_plate_EABC80 * (R51 + R250 + R47)
V_plate_EABC80 = 211V - 0.4 mA * 211Kohms = 126V
But it should be 51V per schematics. What is wrong in above equitation?
I will check the socket connections.
Thanks,
Cuneyt
old measuring instruments
Hi Cuneyt,
possibly the reason for the deviation is the measuring instruments used by the radio repair people.
The values in the schematic are the values measured with the instruments currently used.
look this one of course here
The impedance is about 100k in the 300V range. I estimate, that your modern instrument has 10Meg oder 100Meg.
Edit: In the schematic it is mentioned, that the voltages are measured with a tube voltage meter, this has an high input impedance of 10 Meg or more.
Georg
plate voltage of E(AB)C80
Hi Cuneyt,
Now, you get the answer directly from the former designer of this radios by Grundig, Mr. Hans Knoll:
Hallo Herr Beckmann.
Phänomen ist da nicht viel.
Wenn Sie nur kurz gerechnet haetten Ub(schiene) = 221V. Ra 220+10Kohm =230 Kohm und 0,4 mA Ia macht einen Abfall von 80Volt
220V - 80 V = 140 Volt Da stimmen keine 51, 60, oder 75 Volt.
Das Schaltbild ist falsch.
Der 3055W -3D also ohne Fernbedienung hat einen Ra 200K + 200K zur Siebung.
Der 3055WF-3D hat wegen der FB einen Ra = 200k +10K zur Siebung.
Was das ergibt? 75 volt. Ua.
Anbei eine Kurve in die ich eine 200kohm Gerade eingezeichnet habe.
Bei einem Ia = 0,725 mA, liegen die 75 Volt and der Anode.
Das -Ug1 liegt bei ca. 0,65 Volt.
Also alles O.K.
Gruss Knoll
short summary: The schematic is wrong. There are two types, the 3055W-3D without remote with
Ra 200k + 200k
The type 3055WF-3D with remote Ra = 200k + 10k for decoupling.
With a plate current of 0.725 mA is the plate voltage 75V
grid voltage is about -0.65V
