philips: Ch= K7N; Goya SL - D26K965
? philips: Ch= K7N; Goya SL - D26K965
Count of Thanks: 4
Hello to everybody. I have a Philips Goya D26K965 TV. When I purchased it, it worked fine. It was revised just before I bought it. Few days after it fault. So I opened it to see what appened and I saw that when I push the main power button to on, a spark where produced from an electronic component. I downloaded the electronic schematic from this site of a similar TV with K7N chassis to view electronic components. The corresponding component is R891 which is a NTC thermistor. The problem is that any value is specified on the schematic. So I'm asking: does anybody knows which is the value of this thermistor? Any help will be very appreciated. Thank you!!!
Thermistor
Hello Marco, this thermistor is a special type of Philips. Somewhere (hi) I have an original type.
Regards Wilfried
Check Diodes, please
Hi, Marco,
If this is the NTC in series with the Main Rectifier Diodes, please make shure, to check both Diodes. They carry a very high load, and typically it starts with a faulty Diode, this causing the whole Current using the other Diode, which overloads the NTC.
Hope this helps,
BR Henning Oelkers
