Stuart Matousek
Schem.: 0 Pict.: 1 24.Oct.09 23:14 |
You aren't logged in. (Guest)
1
A new problem has developed with my Concertino. after playing at reasonable volume(not so much to distort the sound) for a minute or two the sound begins to become very distorted. It does not happen after being switched on for a while, in which case I would assume it to be a capacitor which leaks when heated up, only after playing at volume. Does anyone know if this points to a specific area I should look for the fault? |
Emilio Ciardiello
Schem.: 165 Pict.: 583 26.Oct.09 09:23 |
Dear Stuart, Regards, Emilio |
Stuart Matousek
Schem.: 0 Pict.: 1 26.Oct.09 17:49 |
Thanks Emilio, perhaps I should have been clearer about my question.It is when using the radio as an amplifier with an external input that this happens. (maybe it happens as radio too but i dont usually play it loudly in that case). So there is some concern about tha amplifier circuitry, as I said it is not when it is on for a while that it starts to distort, only after playing at reasonable volume for a few minutes.
Stuart |
Emilio Ciardiello
Schem.: 165 Pict.: 583 26.Oct.09 21:12 |
Stuart Matousek
Schem.: 0 Pict.: 1 30.Oct.09 14:39 |
Hi Emilio thanks for your help once again. I am fairly sure I would have replaced that capacitor when I did the initial work on the radio, meanwhile I found another new el84, i think i bought a pair initially, JJ brand from Slovakia. I replaced it and it seems to be fine now.I was just a bit surprised that the tube wore out so quickly as always in the past I have found valves to last almost indefinately and that they are usually the last things to be at fault especially after recent replacement. Anyway I'm happy again now my Telefunken if functioning properly, so thanks again! Stuart |
Emilio Ciardiello
Schem.: 165 Pict.: 583 30.Oct.09 21:43 |
Dear Stuart, Best regards, Emilio |
