aluminum antenna paper
? aluminum antenna paper
28.Nov.19 03:41
30
Jeff Miller (USA)
Articles: 71
Count of Thanks: 18
Jeff Miller
Are there any sources for the "aluminum paper" used inside radios for the FM antenna? The radio I'm looking at (Grundig 2420U) originally had the FM antenna leads (spade lugs) screwed to the aluminum paper, which was glued to the roof of the cabinet interior. At some point, the paper was torn and the connections were broken.
I'm finding "aluminum adhesive tape" online, which seems like it may work, but are there other suggestions, or a purpose-built product? What about using a foil-lined cake box? That would have the paper and foil already merged. Other ideas or solutions?
28.Nov.19 09:26
30 from 2982
Gary Tempest (GB)
Articles: 54
Count of Thanks: 13
Sometimes under the chassis ali foil is used for screening.  In the past I have replaced that with solid thinnest ali sheet.  It might be possible to do that for the aerial as well.
Gary
28.Nov.19 21:50
92 from 2982
Steffen Thies (A)
Articles: 292
Count of Thanks: 17
Your cake box solution is probably best to cut precise shapes. Actually a swedish company is or was offering a laser-cut derivative of their drink box sheets as cheap RF-ID antenna.
Steffen
20.Jan.20 22:23
280 from 2982
Paul Reid (USA)
Articles: 73
Count of Thanks: 18
Real duct tape? That's much better (thicker) than you need. Also has NASHUA printed in red every foot.
I think more like cigarette pack foil-paper, only maybe a little thicker than what they use today. ANY metal conducts 100X better than free space, but as you note the mechanical robustness is marginal at best. You can't find 30 inches of heavy cigarette foil, unless maybe you start a big cigar factory.
Since, unlike the factory, you are not literally pinching pennies, and the stuff has many other uses around the home and audio workbench, I'd just get the aluminum duct tape. Nashua 324A is the good stuff, but there are lesser grades and brands.
Nashua Tape 324A
The brandname may come off with paint-thinner (does no electrical harm, just looks funny inside a radio). The glue sticks good and better with heat (duct or tubes). You can leave it on the paper backing, use a different paper more like the original, or stick the foil right to wood/plastic case. You can double-up where it goes to lugs.
20.Jan.20 22:34
284 from 2982
Gary Streeter (USA)
Articles: 11
Count of Thanks: 17
I second that from Paul.  Go to the hardware store and get aluminum tape that's used in the HVAC industry.  (Different than duct tape that's fabric and sticky.)  You can get plain stuff without the printing, in case that matters to you.  This is what we use in restorations of German (and other) radios.  You don't even have to remove the old stuff, just tape this over it.  This is what we do.
Good luck!
20.Jan.20 22:51
293 from 2982
Jeff Miller (USA)
Articles: 71
Count of Thanks: 16
Jeff Miller
03.Jul.24 00:17
1170 from 2982
Paul Reid (USA)
Articles: 73
Count of Thanks: 15
Retro-thinking: burglar-alarm systems run metal tape around windows. Break the glass, break the tape, alarm sounds. It is narrower than duct-tape and no markings. In the 1940s it was sometimes Lead foil but obviously you won't buy that today.
Apparently the alarm industry has gone over to sonic crack detection (less ugly) but you can still get 9mm 0.35"W foil tape half the length of a football field for $20, AND the screw-blocks to make good contact 2/$9.
tape
blocks
Yeah, that's a lot of FM radios, almost 30?
