AVO CT-160
? AVO CT-160
17.Jul.25 19:00
103
AVO CT-160
Gentlemen,
At the end of 2024, I began converting "Valve Data Manual Edition . 20" AVO Limited’s,  from paper to PDF and then to Excel semi-automatically, with many manual corrections. This was a time-consuming and patient process with the help of a third party.
With the participation of Ueli Kurmann, we were able to create an  Avo CT160  link in RMORG to accommodate the information on 9.796!! valves.
So we created the link:
www radiomuseum.org/dsp_tube_ct160.cfm?tube_name=ECC81
We were pleased to release the 9.796 input lines with 15 columns of valve paramete rs.
Later, when cross-referencing the information using filters in Excel, I found 158 inaccuracies and/or some questions.
Furthermore, the multiple valves (diode/triode or pentado/triode, etc.) were not included. There are more inputs that are not currently covered. I don't know if the system allows multiple inputs for the same tube, but there is the case of the 25CG3 in the second column.
Moreover, special characters like "†   … Ω" are excluded.
That said, I await the willingness of a Senior and/or Moderator to get involved and complete this work, as I have now arrived here and would like to close this matter with the utmost rigor.
I am 100% available to go into more detail. I maintain the files (final and errata), but with notes still in Portuguese ☹
Best Regards
Hernani Capela
AVO CT-160
Meus senhores,
Já no final de 2024 comecei a converter o “Valve Data Manual Edition .20” da AVO Limited  de papel para PDF e depois para Excel de forma semiautomática com muitas correcções manuais, foi com ajuda de terceiro um trabalho demorado e de paciência.
Com a participação Ueli Kurmann conseguimos criar um link Avo CT160 no RMORG para acomodar a informação de 9796!! válvulas.
Assim criamos o link:
Ficamos satisfeitos na altura lançar as 9796 linhas de entrada com 15 colunas de parâmetros das válvulas.
Posteriormente ao cruzar informação por filtros em Excel verifiquei 158 incorrecções e/ou algumas dúvidas.
Mais, as válvulas múltiplas tipo díodo/tríodo ou pentado/tríodo etc.  tem mais entradas que não são comtemplados actualmente, não sei se o sistema permite várias entradas para a mesma válvula, mas existe o caso da 25CG3 em segunda coluna.
Mais,  caracteres especiais como “†0.47MΩ” são excluídos.
Exposto isto, aguardo a disponibilidade de alguém Senior e/ou Moderator para abordar e concluir este trabalho, pois já que cheguei aqui gostaria fechar este assunto com o maior rigor.
Estou assim 100% disponível para entrar em mais pormenores, mantenho os ficheiros (final e errata ) , mas com apontamentos ainda em português ☹
Muito Bem Hajam
Hernâni Capela
