Cigar-box Crystal Radio
Modérateurs:
Ernst Erb Jürgen Stichling Bernhard Nagel
Forum » Technique, réparation, restauration ** » Construction artisanale, construction amateur, Technique Radio » Cigar-box Crystal Radio
Dejan Momirov
Dejan Momirov
RS  Articles: 33
Schémas: 3
Images: 119
06.Mar.12 22:01
Remerciements: 9
Hallo crystalophiles,
On the Internet I have found several crystal radios, built in an cigar-box, and decided to make one myself. First (after emptying the box!), I made a high-Q basket-coil for the tank-circuit. The antenna-circuit have adjustible coupling with it, so I can choose between the sensitivity and the selectivity. Antenna coupling changes automatically, using the second section of the first two-gang cap. The best chosen germanium-diode goes from the top of the coil, to get the highest possible RF voltage. Load to the tank-circuit is minimized by using an self-made impedance-maching transformer, with taps for different phone - impedances. It works good, especially with my extra-sensitive balanced-armature phones (Google will find it under "HIBAPHONE").
So, I would like to share my experience with you.
Regards,
Dejan
Pièces jointes:
Conseiller
D  Articles: 2335
Schémas: 700
Images: 3657
07.Mar.12 19:40
Remerciements: 13
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   2
Hello,
we have a page where you can upload pictures and add text in the picture legend (not in the page) please.
Your forum thread can be moved.
Dejan Momirov
Dejan Momirov
RS  Articles: 33
Schémas: 3
Images: 119
07.Mar.12 23:12
Remerciements: 5
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   3
Sorry, but as a new member I don't know all the possibilities jet. Which page could it be?
Thanks for your advice,
Dejan
Conseiller
D  Articles: 2335
Schémas: 700
Images: 3657
08.Mar.12 10:52
Remerciements: 6
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   4
I am sorry, I forgot the link.
Here is it.
Good luck,
KoBi
