Cross Referrence for Older Hammarlund Super Pro Receivers
Moderatoren:
Jürgen Stichling Ernst Erb Vincent de Franco Bernhard Nagel Mark Hippenstiel Eilert Menke
Forum » Marken- und Firmengeschichten » RADIOFIRMEN / MARKEN im RADIO-MUSEUM » Cross Referrence for Older Hammarlund Super Pro Receivers
Richard MC Clung
Richard MC Clung
USA  Beiträge: 4
Schema: 0
Bilder: 63
01.Jan.07 11:03
1. CROSS REFERENCES FOR COMMERCIAL AND SIGNAL CORPS NOMENCLATURE
Hammarlund Commercial          Equivalent Signal Corps
Nomenclature                             Nomenclature
SP-210-LX                                 BC-779-A
SP-200-LX                                 BC-779-B
SP-210-SX                                 BC-794-A
SP-200-SX                                 BC-794-B
SP-210-X                                    BC-1004-B
SP-200-X                                    BC-1004-C and -D
NONE                                          R-129/U
NOTE: When an R appears in the Hammarlund commercial Model, such as
SPR, it indicates that the equipment is a rack model rather than a
table model. All SP and SPR models are considered to be identical.
2. DIFFERENCE IN MODELS
  a. The external appearences of the receiver and power supply units
for all models are practically identical except that Radio Receiver
BC-1004-D does not contain the S meter. The various models can be
rack or table mounted.
  b. Radio Receivers BC-779-A and -B are alike, Radio Receivers
BC-794-A and -B are alike, and Radio Receivers BC-1004-B and -C are
alike with the exception that in the later issues of each model,
potted type transformers and chokes with terminal boards are used in
place of leads.
  c. Radio Receiver BC-1004-C and -D are identical except for the S
meter.
  d. Radio Receiver R-129/U is exactly the same as Radio Receiver
BC-1004-C except for frequency coverage.
  e. Radio Receivers BC-779-(*), BC-794(*), BC-1004(*), and R-129/U
are funcitionally alike except for the differences in frequency
ranges.
3. FREQUENCY COVERAGE BY MODEL
SP-200-LX       100-200Kc
SP-210-LX       200-400Kc
BC-779-(*)         2.5-5Mc
                              5-10Mc
                            10-20Mc
SP-200-SX    1,250-2,500Kc
SP-210-SX        2.5-5Mc
BC-794-(*)             5-10Mc
                             10-20Mc
                             20-40Mc
R-270/FRR is a BC-794(*) modified for dual diversity operation with
external master oscilator and was part of the AN/FRR-12.
SP-200-X        540-1,160Kc
SP-210-X     1,160-2,500Kc
BC-1004-B       2.5-5Mc
                             5-10Mc
                           10-20Mc
R-129/U        300-540Kc
                      540-1,160Kc
                   1,160-2,500Kc
                       2.5-5Mc
                          5-10Mc
4. POWER SUPLIES
There are three major AC power supplies associated with this series
of receivers with the primary difference of input AC voltages and and
power line frequency.
  a. Power Supply Unit RA-74-(*) furnishes AC and DC operating
voltages for radio Receiver R-270/FRR, or radio Receivers BC-779-A,
-B; BC-794-A,-B; BC-1004-B, -C, -D; and R-129/U.
       Output  380 VDC at 50ma
               250 VDC at 100ma
               100 VDC at 4.5ma
               -50 VDC at 11ma
               6.3 VAC at 7A
      Input    95/105/117/130/190/210/234/260 VAC
               25-60 cycle AC
  b. Power Supply Unit RA-84(*)  furnishes AC and DC operating
               250 VDC at 100ma
               100 VDC at 4.5ma
               -50 VDC at 11ma
               6.3 VAC at 7A
       Input   105/115/125 VAC
               50-60 cycle AC
  c.  Power Supply Unit RA-94(*)  furnishes AC and DC operating
               250 VDC at 100ma
               100 VDC at 4.5ma
               -50 VDC at 11ma
               6.3 VAC at 7A
       Input   115/230 VAC
               50-60 cycle AC
  d. This series of receivers may also be operated from DC batteries.
       One 6 volt storage battery for A+ filament supply
       Five 45 volt B batteries for B+ supplies
       One 45 Volt C battery for C- supplies
5. IMPROVEMENT KIT MC-531
  a. The Improvement Kit MC-531 is designed to stabilize the
operation of the radio receiver under conditions of varying line
voltage and ambient temperature changes by means of a crystal
oscillator which provides for crystal-controlled reception at any one
of the three signal frequencies, in the frequency range of 1.5 to 20
Mc. It has a delta tuning control to make slight adjustments to the
received signal.
Some more trivia,
MACKAY RADIO AND TELEGRAPH COMPANY
HF COMMUNICATIONS RECEIVER
MODEL CNY-1176B (SP-400-X)
Modified for FSK using Northern Radio HFO/BFO Master oscilator.
Additional modifications included:
MACKAY Model BNY-1798 Mechanical Filter Adapter. This removed the
Crystal Selectivity Filter assembly and replaced it with a Collins
1.8 Kc BW mechanical filter (F465K25).
Another MACKAY modification replaces V1 6K7 1st RF Amplifier with a
12AT7 Cascade 1st RF Amplifier.
RICH  WA6KNW
