Dial Light Bulbs Source
Count of Thanks: 4
In restoring radios, it has been difficult to find some of the dial light bulbs. For some time I thought I'd never find a source for the "ba7s" base used in German portables. These usually run at 6-7v. Finally, I found a the firm Farnsworth Electronics, with bulb page: www.farnsworthelectronics.com/miniaturelightbulbs.htm. They also provided the source for wedge based bulbs used in some Nordmende portables. The order desk has been very helpful, prices are reasonable, service excellent, and they do not have a minimum order amount.
Regards,
Ron
from stock
look at order number 33G180
they have an english web-page too.
If you have problems to order from Buerklin, please send me a mail, we have any other day something to order and I would like to send you this.
Best Regards
Georg
dial bulbs
there 3.5 according to my avo, on the holders , these kind of bulbs are as scarse as hens teeth here , would u be a dote and enquire through ur source and il l be very much obliged to u , regards maitiu.
Light bulb
Which is the one you want and how many ?
Georg
- bulb (29 KB)
dial lamp/skalen lampe
I am also having problems finding dial lamps for the 1932/1933 Saba's. They have a cone at each end and are 4V.
Thank you,
Donald Cochrane
EE 3. Nov 07: eMail-Address deleted
are these bulbs for your Philips 525A, by any chance?
If so, then according to my service data they were Philips
type 8046, if that's of any help, and I think the metal part
(bayonet fitting?) is 15mm. (9/16") diam. (confirm?)
This is the same physical size as old fashioned car or m/cycle
side lamp bulbs, though I don't suppose they come in less
than 6v.
If Georg or any of our Philips friends can't help you could break
out the glass (very carefully!) of the old ones and fit in an MES
holder, wire in a smaller bulb or even led's!
http://www.farnell.com used to stock a wide range of bulbs,
might be worth a look.
Good luck,
John.
Soffittenlampe
There are lots of types in different lengh and diameters and voltages 4V I didn't find in a first look. 6V are ok.
Georg
8046 w
bulbs
if that is the case i might get them handy enough in a motor bike outlet here in dublin ,
would they light up bright enough ??? regards maitiu.
if you can get some 6v. m/cycle bulbs, give 'em a go,
wouldn't go higher than 3w. max though, 2 or 2.2w. might just
give enough light.
Keep us posted,
John.
dial bulb
anyway im well pleased with it , and it works well ,hope im able to iron out the other faults as easy , fondest regards , maitiu.
bulbfondest regards maitiu
