Dial scale lamp
? Dial scale lamp
08.Sep.20 15:24
122
Hello,
In one of radios I found a quite strange dial scale lamp.
The lamp is about 5 cm long total, bulb 4cm . Problem is there is no marking on it. What is more filament is broken. I suppose is Philips or Osram.
Have you ever seen this kind of lamp? What type is this?
Which model page please?
10.Sep.20 19:28
122 from 1300
Can you please tell us the model page of the set with this lamp? One should post from the object to get a sticky article to the model page.
If the model is not in the data base, please propose it and tell us to move this post to the model page. Then you have much better chance for a good answer.
