EM71 Repair
? EM71 Repair
- Bottom of EM71 (42 KB)
- EM71 pattern screen (25 KB)
This thread was moved automatically.
Getter and glass nipple
Hello Lars,
Too bad that this rare tube is broken.
Attaching a new glass nipple between the pins would be very difficult without disturbing the pins. Perhaps it could be done with a vacuum grade epoxy.
Then there is the problem of putting a fresh getter in the tube.
The getter is highly reactive metal that is deposited in the interior of the glass and looks mirror-like. It traps the last remaining oxygen atoms after a full vacuum has been done.
When the glass broke, this metal mirror oxidized pretty quickly into a white film.
The closest thing I have seen to what you are asking, was in a video on YouTube, where CRT's were hand made at home.
In this case, getters were not used. The vacuum was adequate to light up the phosphor without internal arcing, but might have been too gassy for amplifier use, causing excessive grid leakage.
I suppose the greatest barrier to seeing this tube lit up again would be getting a new glass nipple between the pins.
I also don't know if the phosphor in the DM71 would have been damaged by now, from exposure to air.
Regards,
-Joe
EM71
Thank you Joe for the reply!
I guessed that it would be too tricky to get this EM71 working again because it's likely that the tube also is soiled with dust inside too.
Well, nothing to cry about.
Wishing a Merry Christmas and a Happy New Year!
Lars-G.
