File upload at a glance
Dear all,
Here first how to treat pictures with a free picture software program, IRFANVIEW. At least the instruction is worth while. Use big sized pictures with a big object in them.
Upload to | Content | File Format |
Color |
B/W 2-6 grey- scales |
B/W 16+ grey- scales |
Prefered file size kB |
Max. file size kB |
Width, pixels (max.) |
Height, pixels (max.) |
Models |
Pictures |
.JPG .GIF .PNG |
yes | no | yes | 300-600 | <= 600 | 1400 |
2100 |
Schematics [4] |
.PNG .GIF |
[4.1] |
yes |
no |
<= 600 |
5000 Scan 300 DPI |
5000 |
Makers [5] |
Pictures | .JPG | yes | yes | yes | 300-600 | <= 600 | 1400 | 2100 |
Tubes | Pictures | .JPG | yes | no | yes | 600 | 1400 | 2100 | |
Socket diagram | .PNG .GIF |
no | yes | no | 150 fix | 250 | |||
In circuit diagram | .PNG .GIF |
no | yes | no | as low as possible |
640 | 700 | ||
Charac- teristic |
.PNG .GIF |
Scan 300 DPI Animated GIF 150 fix! |
Forum | Pictures [2] |
.JPG .GIF |
yes | yes | yes | <= 120 ! | 600 | ||
Spread- sheets [3] |
any Text, small pictures |
yes |
yes | yes |
600 | ||||
Attach- ments |
.JPG .GIF |
yes |
yes |
yes |
<= 200 ! | |||
Articles: Editor- Instructions ! |
Your contribution is welcome. We are polite and respect each other, and avoid bad words. For problems we turn to an administrator or to the Mediator. |
Private | Pass- port photo |
.JPG .GIF .PNG |
yes | no | yes | as low as possible |
<= 50 ! |
150 fix | 200 ! |
Pictures | .JPG .GIF .PNG |
<= 600 |
1400 | 2100 |
Please click on the bold underlined Links for additional information.
[1] Pictures of a tube (valve) should display the tube (valve) only. Please cut your pictures accordingly.
[2] Pictures for the Forum should be of reasonable size before upload, not shrinked after upload. Another "how to" is here. You can add high-res pictures and schematics using the Attachement(s) button beside of Submit .
[3] Even if you have preset the table width to 600 pixels you have to check wether the size may have increased by adding some entries. Enabling multiple lines for a cell will help you.
[4] Pixels at 300 dpi. A circuit diagram must be (rotated if necessary) in portrait mode, top to the left, the dimensions are rule. PDF is not allowed. A must to read is the "how to" here.
[4.1] For modern schematics printed in colors you find an orientation here. A special instruction is not yet available. If in doubt consult the schematic administrator.
[5] "Makers" is synonym for manufacturers and brands.
The above data are collected from all the i I have found.
Please click on [ Mail to the author ] in case of any complaint or suggestion.
Kind Regards
Georg
