saba: Freudenstadt 11, asking administrators
? saba: Freudenstadt 11, asking administrators
Dear Administrators,
I have a Saba Freudenstadt 11 Stereo International model. Export model that shares many characteristics with the domestic model on this page, but is not the same. The dialglass is different and the FM band extends up to 108 MHz. I have attached photos for comparison.
I ask the Administrators if this model should be included as a variant here or should I propose it as a new model.
Cordially,
Bruno.
Hello Bruno,
This model is most likely the 200 Stereo/11 - please verify. It might be that the back cover of your radio was replaced at some point.
Kind regards
Mark
Hello Mark,
Thanks for replay.... the back cover is original and the radio model is Saba Freudenstadt 11 stereo International, please see a better attached photo.
But they are other differences..
1. You can see my model has different dial glass to the 200 Stereo/11, named SABA INTERNATIONAL on the right side (also on the back cover) and they are not radio stations.
2. My set has LW/MW/SW/FM instead of MW/SW1(Marine)/SW2/FM as the 200 Stereo/11 has.
3. Rectifier: B 250 C 100 instead of B 250 C 125.
Cordially,
Bruno.
Hello Bruno,
Thanks - that was not apparent from the images you sent. Quite a few models were "modified" with a sticker in this way by Saba; I recently looked at a few of those. It's not uncommon.
But in this case, yes, please suggest a new model for your radio.
Thank you and kind regards
Mark
Thanks Mark, the new model was proposed.
Best regards,
Bruno.
