Help for identification of radio console
? Help for identification of radio console
30.Mar.19 18:58
Georges Van Campenhout † 28.4.22 (B)
Articles: 206
Count of Thanks: 2
Goor evening radio lovers,
who can help in the identification of this radio console?
Th only tube with readable type number is the rectidier PV495
Thank you
30.Mar.19 19:23
8 from 724
Garrett Walsh (USA)
Articles: 30
Count of Thanks: 2
Hello,     What I see so far is your console looks like a radio from England made in the 30's or 40's. But more pictures are needed especially the rear part of the radio and a close picture of the dial. Also look for any labels or numbers stamped on the chassis or on the inside of the cabinet. If there is a back cover there should be a license or tax number if it is a British radiio. Another clue would be the plug for the power cord. English radios ran on 220-240 volts. Hope this helps
Schaub Bristol W
31.Mar.19 00:20
50 from 724
Officer
Articles: 1619
Count of Thanks: 2
Most probably your console radio is this model: Schaub Bristol W from 1931/32. A similar model can be found here: Windsor W, which has a record player in the top.
Please load your pictures in high resolution to Bristol W since most of the present pictures there are of bad quality or too small.
Thank you.
