Kolster Brandes (UK) Model 'numbering' scheme |
Mike Edwards † 25.10.21 Schem.: 1534 Pict.: 4260 29.Aug.13 22:35 Count of Thanks: 9 |
Reply | You aren't logged in. (Guest) 1
From approximately 1928 to before 1946, an incrementing 3 digit number. "KB" prefix is optional, From about 1946 to 1964, generally but not exclusively 2 alpha characters followed by 2 numerals; See Below From about 1965, many models prefix with K The 1st letter is approximate year. Some letters are skipped and some years get two letters. A 1945 to 1946 No production, shortages. Maybe 1944 & 1945 they made some Civilian Sets? 1941 to 1944 likely only Military production if any. B 1947 (maybe delayed from 1946) C 1947 D 1948 E 1949 F 1950 G 1951 H 1952 I (Not used, too much like 1?) J ( not used) 1953 (presumably or did they take a year off?) K 1954 L 1955 M 1955 N 1956 O 1957 P 1958 Q 1959 R 1960 S 1961 T 1961 U 1962 V (Not used?) W 1963 X 1964 (some TVs) A Amplifier / Audio B Baby mains radio, not always L & M can be even FM only G Radio Gram function on a Radio P Portable (seems pretty consistent). Battery valve or Transistor. M At least MW Mains Radio, not baby or gram R Radio All Wave Mostly but not always LW MW, SW (can be LW, MW & VHF), if Export then more SW instead of LW. What else might "R" stand for? RP Record Player without Radio S Speaker T Tape or Transportable Radiogram Why is this RT10 not called an RG10? is it because it is Transportable!? V TV F TV FT TV Usually two digits. If a 3rd digit its the same product segment as a similar earlier xYnn model, if a /n suffix then the year letter is when original released and it's a revised design. Letter then isn't the release year. 1st numeral Probably just an indicator to identify the style or grade 2nd Numeral 0 = AC Mains
3rd letter T=Tropicalised/(export version), L=low voltage(110-125)
SUMMARY
Mike Edwards, Michael Watterson This article was edited 13.Nov.13 13:08 by Mike Edwards † 25.10.21 . |
Michael Watterson
IRL Articles: 1000 Schem.: 650 Pict.: 2497 01.Sep.13 13:11 Count of Thanks: 7 |
Reply | You aren't logged in. (Guest) 2
Probably produced from about mid 1944 to 1945. These came in various versions, battery & mains. Kolster Brandes Wartime Civilian Utility Radio code U32 |
