stromberg: name of screws for front panel
Modérateurs:
Martin Renz Ernst Erb Vincent de Franco Martin Bösch Mark Hippenstiel Bernhard Nagel Dietmar Rudolph † 6.1.22 Otmar Jung Heribert Jung Eilert Menke
Forum » Radios, TV, Appareils techniques (Physique) etc. » MODÈLES PRÉSENTÉS » stromberg: name of screws for front panel
Wolfram Zylka
Wolfram Zylka
Rédacteur
D  Articles: 582
Schémas: 3
Images: 411
04.Aug.20 19:52
Remerciements: 2
I am looking for the screws that fix the front panel for the device Does anyone know the exact name of these screws Thanks for your support
Best Wishes
Wolfram
Lindsay Shepherd
AUS  Articles: 11
Schémas: 40
Images: 2385
05.Aug.20 02:01
Remerciements: 3
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   2
They are Round Head slot wood screws ( brass or stainless steel is best) select the correct size.
regards
Lindsay Shepherd
Wolfram Zylka
Wolfram Zylka
Rédacteur
D  Articles: 582
Schémas: 3
Images: 411
05.Aug.20 13:11
Remerciements: 2
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   3
Thank you very much for your comment
In this case, the screws are fitted with a metal threat Enclose I made a sketch
In Metric measurements it would be not a problem to identify.
I like to find out the right name for it screw with the American Inch measurement
Pièces jointes:
Cet article a été édité 05.Aug.20 13:14 par Wolfram Zylka .
Rolf Beckers
Rolf Beckers
Rédacteur
D  Articles: 195
Schémas:
Images: 652
05.Aug.20 18:03
Remerciements: 3
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   4
Hello,
These are metric lens-senkhead screws or in German Linsen-Senkkopf-Schrauben.
Regards,
Rolf
Wolfram Zylka
Wolfram Zylka
Rédacteur
D  Articles: 582
Schémas: 3
Images: 411
05.Aug.20 20:13
Remerciements: 2
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   5
Thank you very much
Unfortunately the threat is not metric
I like to keep in original condition  and would
like to bye those screws.
But I don’t know what shall I look for
Regards Wolfram
Mark Hippenstiel
Mark Hippenstiel
Modérateur
D  Articles: 1252
Schémas: 3398
Images: 18046
06.Aug.20 04:21
Remerciements: 2
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   6
The Biritsh standard that can be found on some old UK devices would be Whitworth aka BSW British Standard Whitworth, or BSF British Standard Fine.
In America, the corresponding standard is UNF (see Wikipedia) but the manufacturer might have used something else for this model at that time.
The shape is called oval or raised head (in the UK "raised countersunk").
You're probably looking at a #6-40 or #8-36 screw, depending on accuracy of measurements.
Your best bet is to send a sample to a seller to make sure you buy something fitting -- unless you can reliably determine the threads per inch and pitch.
Hope that helps, and good luck,
Mark
Wolfram Zylka
Wolfram Zylka
Rédacteur
D  Articles: 582
Schémas: 3
Images: 411
06.Aug.20 12:21
Remerciements: 2
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   7
Hello Mark
Thanks a lot for your detailed information.
I measured the screw carefully
It should be it one :
8-32 X 1 Inch Raised Slotted Countersunk Screw
Now I’m going to find a supplier
Best regards from Ireland
Wolfram
Cet article a été édité 06.Aug.20 20:32 par Wolfram Zylka .
Wolfram Zylka
Wolfram Zylka
Rédacteur
D  Articles: 582
Schémas: 3
Images: 411
15.Nov.21 13:22
Répondre  |  Vous n'êtes pas connecté, mais en mode visiteur   8
I have done the screw procurement. With success. I ordered suitable screws from Accu in Great Britain and received them after 4 days. Enclosed the data of the order process If any of our members are looking for screws for English or American radios: Based on good experience, I can recommend this supplier
Best regards
Wolfram
Accu
Hagg Wood Stone Quarry
Huddersfield, HD9 6PW
United Kingdom
tel: +44 (0) 1484 937010
fax: +44 (0) 1484 937020
e-mail: sales@accu.co.uk
website: www accu.co.uk
Accu Limited
Registered in Company No: VAT No: GB136780105
SFRK-8-32-1-A2 8-32 x 1 inch Raised Slotted Countersunk Screws (ANSI B18.6.3) - Stainless
Steel (A2)
Price   €  0.41 x 8 = € 3.28
Cet article a été édité 15.Nov.21 13:22 par Wolfram Zylka .
