Parameters for an acceptable germanium transistor
? Parameters for an acceptable germanium transistor
07.Oct.17 22:24
71
Omer Suleimanagich (USA)
Articles: 429
Count of Thanks: 7
Omer Suleimanagich
From all the research I have done, many conclude that germanium transistors should only be used if their measured leakage is less than 300uA or 0.300 mA
Can anyone on RMorg confirm this?
08.Oct.17 17:43
71 de 2036
Michael Watterson (IRL)
Articles: 1037
Count of Thanks: 6
It depends on the test temperature, test voltage, if base is open or connected to emitter and the exact device. They are very temperature sensitive and very voltage sensitive.
Leakage is more important for signal devices than power devices. You need to examine the circuit it's used in and the device data to decide if the leakage is a problem.
I would test with base connected to emitter, 3V supply (or half the application HT voltage) and at 20 degrees C or less. A hot climate will give high readings.
Certainly at 20 C and 3V, with base to emitter, the 300uA might be far too high unless it's a power device. At 30 C and 20V, the 300uA might be misleading.
08.Oct.17 20:54
90 de 2036
Articles: 429
Count of Thanks: 6
Omer Suleimanagich
So in practicality, what you are saying is, power germanium transistors can be leaky (above 300uA) in an amplifier circuit
What about germanium transistors used in the IF, RF, or predriver sections of an FM?
08.Oct.17 22:43
105 de 2036
Articles: 1037
Count of Thanks: 5
Even 300uA might be far too high.
You need to measure at 20 degrees C and 3V or at worst 1/2 the HT voltage. In that case I'd expect very much less than 100uA, but leakage can be very high at higher temperatures and/or higher voltages. Consult the data sheets.
09.Oct.17 05:36
117 de 2036
Articles: 429
Count of Thanks: 5
Omer Suleimanagich
Actually, I am using one of these,
PEAK Atlas IT (DCA Pro) ADVANCED SEMICONDUCTOR ANALYZER with Curve Tracing
