Philips - Bratpfanne Loudspeaker 2003
? Philips - Bratpfanne Loudspeaker 2003
08.Oct.20 13:14
46
I have just acquired a "bratpfanne" - I think its a model 2003 ~40cm diameter.
The speaker cable has 3 wires.
Is it possible to select the impedance of the speaker ? If so, what are the impedances ?
I have looked at the French Service Documentation on this site but apart from mentioning 2 or 3 wire cables there was no discussion (or diagram) on what the difference was.
Thank you.
08.Oct.20 18:15
46 from 757
If you search the net with Phlips luidspreker 2003 omschakelinrichting you will find a lot of information about the speaker.
excerpt:
