general-el: Power tube S-22
? general-el: Power tube S-22
30.Aug.17 19:04
67
Mauro Cattaneo (I)
Articles: 2
Count of Thanks: 6
Mauro Cattaneo
Hello, on my S-22 chassis on the paper stamped on the back side i read, back of 80 tube, two TUBE  RCA UY247, there are missing, while looking the schematics there are two 45 tubes, what are the right tube i va to insert?
regards,Mauro
31.Aug.17 21:14
67 from 1502
Steffen Thies (A)
Articles: 287
Count of Thanks: 5
Hello Mauro,
if you check the data here, you will see that the 247 is a penthode with the same heater voltage as the 45. So this may be a later upgrade. A look at the socket will show which it is!
Regards,
Steffen
