marconi: R8 & R9 values and others tips found on schematics |
Vicente Moncholi-Cebrian
Esquemas: 139 Fotos: 220 15.Apr.18 21:08 Agradecimientos totales: 2 |
Respuesta
Usted no ha entrado su «login».(Invitado)
1
Hello everyone, I am currently working on the restoration of a G.E. Marconi model 633W15 Type 296, and I found some differences with the schematics that is in the model information in RadioMuseum.
I hope this information is useful. Regards, Vicente Moncholi - Seville - Spain
Mark Hippenstiel
![]() Moderador
D Artículos: 1215
Esquemas: 3036 Fotos: 15665 18.Apr.18 01:25 Agradecimientos totales: 4 |
Respuesta
Dear Vincente, Thank you very much for this information. An identical schematic as shown here was uploaded to model Marconi Six (first series). Both files do not have original model or chassis information, this was added later. Furthermore, the schematic present here had "Typ 296" added to it while the model is a type 295. I have deactivated both as they were modified and are not strictly pertaining to those models - you can still find the complete schematic from the Schmémathèque Toute la Radio with notes at model Pathé 64. As you can also read in the model remarks on both models, there are differences between chassis versions that we do not (yet) know. Currently the known chassis 633W, 633W1 and 633W15 are grouped together for simplicity. Perhaps you can upload an image of the type plate for clarification. You write "633W15 Type 296" while we list this model as type 295. Unfortunately, the images present here don't have a sufficient resolution to read the plate. Thanks and kind regards Este artículo fue corregido 18.Apr.18 11:54 por Mark Hippenstiel . |
Mark Hippenstiel
![]() Moderador
D Artículos: 1215
Esquemas: 3036 Fotos: 15665 18.Apr.18 13:01 Agradecimientos totales: 3 |
Respuesta
I have submitted changes to the model to change the type from 295 to 296. This information was introdcued by me in 2016 based on the model name ("Marconi Six") and the available data at the time. Also I have rephrased the model text to clarify that the "equivalent" Pathé model can be slightly different. We currently have no information if type 296 was delivered with chassis 633W, W1 or W15 - I am assuming that it's probably starting from 633W15 as this is a newer version than the original 633W. We can only collect the data and come to a conclusion later on when sufficient evidence is present, or when we get hold of an original service manual. Thanks again, |
Esquemas: 139 Fotos: 220 23.Apr.18 14:46 Agradecimientos totales: 4 |
Respuesta
Hi Mark, thanks for your inputs. I´m trying to do my best with this radio, correcting issues and verifying changes on schematics. It seems I received a set complete with all original components, but in very poor condition: dust from decades inside, components degraded out fo tolerance,... Has been very painful to put radio set to work because it needed to reconstruct almost all, including lot of cabling, the two capacitor blocks, dc filter capacitors, substitued all resistors except two, and all capacitors, and the type 47 tube. Fortunately inductances and IF cans are OK, except discrete components inside, speaker and excitation inductance are OK, AF transformers OK, Westector OK. By the way, I tried to susbstitute Westector with a pair of 1N54A and it worked, and then returned Westector on place to maintain it inside. Here I attach photo of model and type. When finish all test I download a corrected schematics as verified phisically on radio. Thanks and regards, Vicente Moncholi Anexos:
Esquemas: 139 Fotos: 220 24.Apr.18 22:29 Agradecimientos totales: 5 |
Respuesta
Hope this info can help. I have investigated the wiring of the speaker area to clarify the connection scheme from the radio chassis to the terminal strips plate.
Vicente Moncholi-Sevilla - Spain Anexos:
Esquemas: 139 Fotos: 220 29.Apr.18 17:26 Agradecimientos totales: 5 |
Respuesta
Hello everyone, radio set now working OK. Please find attached final schematics based on radio Pathé 64, updated as wiring and components found and verified on the radio Marconi Six model 633W15 Type 296. Hope this may help others working on this radio. Regards, Vicente Moncholi - Sevilla - Spain Anexos: |
