telefunken: Telefunken Dacapo 9 Export - electrolytic replacement
Moderadores:
Foro » Radios etc. » MODELOS DEMONSTRADOS » telefunken: Telefunken Dacapo 9 Export - electrolytic replacement
Steve Browne
GB  Artículos: 4
Esquemas: 0
Fotos: 0
15.Aug.12 21:30
Agradecimientos totales: 4
Has anyone replaced the ratio detector electrolytic on this model?  It appears to be contained within a screening can surrounding the EABC valve and containing the demodulator inductors.  Does the top of the can lift off without desoldering everything from below?  Is it acceptable to leave this original component and simply replace the accessible electrolytics?
Thank you.
Emilio Ciardiello
Emilio Ciardiello
Redactor
I  Artículos: 529
Esquemas: 165
Fotos: 790
16.Aug.12 19:23
Agradecimientos totales: 2
Dear Steve,
if the old capacitor is not shorted, you can add a new one outside the discrimainator subassembly. Give a look at this article from Bernhard Nagel.
