siemens: Tube sustitute for rectifier RGN354 |
Vicente Moncholi-Cebrian Schem.: 139 Pict.: 220 10.Oct.20 21:00 Count of Thanks: 3 |
Reply | You aren't logged in. (Guest) 1
Hello, Hallo, ola,
Jacob Roschy ![]()
D Articles: 1730 Schem.: 17 Pict.: 68 13.Oct.20 20:47 Count of Thanks: 2 |
Reply | You aren't logged in. (Guest) 2
Hello, this method can be used for a short time as makeshift, but it's not recommended for permanent use, as the unused cathode will then spoil. If a fullwave rectifier tube RGN1054 or -1064 should be permanently used as a replacement for a RGN354, both anodes must be connected each other. This was often used on VE301W sets. Best Regards, Hallo, als Notbehelf kann man diese Methode kurzzeitig anwenden, für dauerhaften Gebrauch ist es nicht zu empfehlen, da dann die ungenutzte Katode verdirbt. Soll eine Vollweg- Gleichrichterröhre RGN1054 / 1064 ständig als Ersatz für eine RGN354 dienen, müssen beide Anode überbrückt werden. Dies wurde im VE301W oft angewandt. Beste Grüße,
ola, este método puede utilizarse durante un corto tiempo como improvisado, pero no se recomienda su uso permanente, ya que el cátodo no utilizado se echará a perder. Si un tubo rectificador de onda completa RGN1054 o -1064 debe ser usado permanentemente como reemplazo de un RGN354, ambos ánodos deben ser conectados entre sí. Esto se usaba a menudo en el VE301W. Saludos, |
Vicente Moncholi-Cebrian Schem.: 139 Pict.: 220 14.Oct.20 13:04 Count of Thanks: 2 |
Reply | You aren't logged in. (Guest) 3
I fully agree with you, so, I will make the mod suggested directly on the tube. Thanks a lot. Vicente Moncholi |
Jacob Roschy ![]()
D Articles: 1730 Schem.: 17 Pict.: 68 15.Oct.20 17:36 Count of Thanks: 2 |
Reply | You aren't logged in. (Guest) 4
However, it should be noted that this tube poses a danger now: if someone want to use it as a two-way rectifier again, it will cause a short circuit. Jacob Roschy
