Unidentified tube
? Unidentified tube
23.May.16 18:43
25
Dejan Momirov (RS)
Articles: 34
Count of Thanks: 5
Dejan Momirov
Halo radio friends,
I've just got a small vintage tube which I can not identify. It has a 4-pin base and is about 4cm tall in total.
Between pins 2 and 4 is a thin wire of 1.2 Ohm DC-resistance.
Across it there is a second. much thinner wire, connected to pins 1 and 4.
Its resistance I could not measure! Maybe there is open circuit, or the resistance is very high, beyond the range of my multimeter. It could be a sort of current regulator, or a sort of Hot Wire Barretter. Does anybody recognize this tube, or has some idea about it?
Thanks, Dejan
Thermocouple ?
23.May.16 21:09
25 from 2859
Articles: 1766
Count of Thanks: 6
Hello Dejan,
this appears to be a Thermocouple, apparently burnt out, due to the open circuit between pins 1 and 4.
Best Regards,
Jacob
Unidentified tube
24.May.16 13:13
97 from 2859
Dejan Momirov (RS)
Articles: 34
Count of Thanks: 5
Dejan Momirov
Thank you Jacob, That's it !!
I have made mistake by typing: What appears to be the thermoelement is connected to pins 1-3, and NOT to 1-4 as I wrote. Sorry,
Best regards,
Dejan
Philips / Valvo TH5
24.May.16 14:29
106 from 2859
Gidi Verheijen (NL)
Officer
Articles: 248
Count of Thanks: 6
Gidi Verheijen
Hello Dejan,
Judging from the exterior of your thermocouple tube and the resistance of 1,2 Ohm for the filament section, it very likely is a Philips or Valvo TH5.
See TH5 Philips.
I once used such a thermocouple to build a RF miliwattmeter, whereby the RF source heated the filament, thus generating a thermal voltage across the thermocouple. This voltage was a measure for the RF power. The connections have to be kept very short in this design in order not to introduce unwanted resistance at RF frequencies. The nice thing of such a device is that you can calibrate the instrument with a simple and accurate DC source.
These thermocouples are very delicate and vulnerable. I still have a few species of the Philips TH1, TH2 and TH5 in my collection.
Best regards,
Gidi
Thermocouple tube
25.May.16 09:58
161 from 2859
Dejan Momirov (RS)
Articles: 34
Count of Thanks: 5
Dejan Momirov
Thanks Gidi,
A nice idea to make RF miliwattmeter, but it seems to be an opencircuit in the thermoelement line - should it be any resistance or voltage at room temperature. I could not measure any!
Best regards,
Dejan, YU1NGL
Open circuit
26.May.16 00:54
200 from 2859
Gidi Verheijen (NL)
Officer
Articles: 248
Count of Thanks: 4
Gidi Verheijen
If your thermocouple tube really would be a TH5, the resistance of the thermoelement section should measure 3,5 Ohm. See table.
Unfortunately your thermoelement certainly is an open circuit.
Regards,
Gidi
