Vowel mutation - how to achieve?
12.Aug.04 11:29
Officer
Articles: 5751
Count of Thanks: 13
Foreign languages often use special letters (characters and vowel mutation). There are different ways to achieve that:
1.
If the keyboard shows such signs like ¨, ^, ´, ` etc.
You can type first the sign and then the character.
2.
If not you can use the Alt-combination:
You hold the Alt-key (left hand) and at the same time you type numbers in the right number board. Examples:
for German:
Ä = 142
ä = 132
Ö = 153
ö = 148
Ü = 154
Ü = 129
other examples:
ç = 135
ñ = 164
é = 130
á = 160
â = 131
etc.
3.
You can reconfigure your keyboard in the system - but this is akward since you don't see the right characters if you have not marked them.
18. Dec. 2007:
Below you find a good other solution.
With RM.org Editor use "Sonderzeichen einfügen/editieren"
18.Dec.07 11:18
Articles: 2441
Count of Thanks: 19
The RM.org editor has a very comfortable possibility for generating special vovels.
The last button in the second head line calls up a table with often needed special characters.
This fourth way is probably the easiest one.
Best regards, Dietmar
19.Dec.07 08:34
Articles: 1786
Count of Thanks: 10
You can facilitate typing in special characters by using the auto-correct function of your text program.
Then you can use normal characters on your keyboard which will be automatically replaced by special characters.
Some useful replacements in our field may be:
mu  →  µ
uf  →  µF
pf  →  pF
nf  →  nF
om  →  Ω
ko →  kΩ
mo →  MΩ
ae  →  ä
oe  →  ö
ue  →  ü
mm2  →  mm²
Best Regards
Jacob
