taylor: 65B; All-Wave Signal-Generator: Theory and Operation
Moderadores:
Martin Renz  Ernst Erb  Wolfgang Bauer  Jürgen Stichling  Arpad Roth  Vincent de Franco  Martin Bösch
Foro » Radios etc. » RADIO MODELS DISPLAYED » taylor: 65B; All-Wave Signal-Generator: Theory and Operation
Michael Watterson
Redactor
IRL  Artículos: 524
Esquemas: 459
Fotos: 1288
09.Mar.12 00:33
Agradecimientos totales: 2
Usted no ha entrado su «login».(Invitado)   1
I found an Instruction manual (Search for "Thevalvepage"). The manual has a basic schematic but without any values. Another feature of the manual is the three Appendixes:
1: Adjustment of Receivers and Amplfiers
2: Frequency Conversion Tables
3: Intermediate Frequencies (Originally 14 pages of IF for Radio Sets of Radio up to 1940s).
All designations are according to my annotation of schematic
Circuit Description
The mains connects to on/off switch on the Modulation Int/Ext control and voltage selector via a filter C1 ... C4 & L1, L2. The switch and voltage selector connect to the mains transformer T1 which has 110V, 210V and 240V taps. On the 240V tap a Mains voltage of about 230V is roughly 6.2V on the heaters. The transformer gives 6.3V AC for heaters and dial "on" indicator and 110 - 0 - 110 V AC for 6X5 "fullwave" rectifier.
The HT PSU is the 6X5 cathode feeds C5, R1 & C6 filter.There is about 100V on C6.
Audio Section
The 6J5G (V2) is optionally modulating the HT voltage for V3, the 6J5G RF oscillator. When 400Hz modulation is selected the C7 (30nF) is connected to T2 on the Anode of V2 and then to grid via C8 (50nF). The Inductance of all of T2 and C7 sets the 400Hz. A variable level (VR1, 10 K Ohms) 400Hz is thus available on the 1/4" mono jack socket. When in "Ext Mod. CW" position the jack socket is switched to C8 and V2 is simply an audio amplifier. C7 is disconnected. T2 is then Audio load for V2 and V3 RF oscillator HT is via a tap on T2 as before. Thus with nothing connected to Jack socket the RF oscillator isn't modulated, i.e. "CW" (Continuous Wave) mode. If there is a signal then V2 and T2 are a Traditional HT "AM" drive (as used even on old Transistor AM CB sets). Grid bias is by a 910 Ohms cathode resistor that isn't decoupled presumably for some negative feedback to try and improve audio quality. On Internal 400cps (400Hz) the modulation is about 30%
RF section
Curiously the 6J5G has no cathode resistor. However HT is lower than on the Audio section. There are in reality only  5 bands. If you need more than 23 MHz you just tune the radio to the harmonic (about 20dB to 30dB lower depending on band) and there is a 16MHz to 46MHz "scale" that assumes you have selected the 8MHz to 23MHz band.
A single capacitor tunes across the band with five different parallel coils and five parallel trimmers to align the HF end of each band on the grid of V3, 6J5G. R4 is the anode load fed from "modulation transformer" HT (T2). Five more "band" coils are switched in series with C10 connected to Anode. I'm not sure if I have the values of C9 (500pF) and C10 (2nF) the correct way round.
R4 (anode load) and R5 (grid) are somewhere under the tube base (valve socket). I can't see them. If I was really energetic I could have unplugged valve and measured, though these parts are usually 20% tolerance and may have drifted, so a measurement isn't the same as reading the value!
R5 on the Grid of V3 (6J5G) feeds VR2, the RF adjustable level (2K ohms?). The wiper feeds the attenuator box with a 9 way switch and RF out connector.  Alternate positions of the switch are used to increase isolation, so there are five levels. Into 50 Ohms the level increases with increasing frequency, a maximum of -40dBm at 1.5MHz and peaking about -35dB at some frequencies.
The RF connector is like a "battery Set" LT 1.5V connector. I made one out of plastic, coffee tin and glue gun on an RG58 coax with BNC at other end.
In theory the the Attenuator is -20dB per step, (x10) but this depends on good sealing of the attenuator section cover and correct load.
Conclusion
This model can be just a "Collectors Item" or used to actually align RF & IF of AM sets if you know what you are doing. A decent new RF signal generator with attenuator good enough for direct connection to an aerial socket is €400 to €2000. You can just use a cheap DDS module (€7) but you need a CPU and GUI to program it also filters and quality 0 to 80dB attenuator on the output. For a 65 to 70 year old simple design of RF signal generator it works quite usefully. A "listening" test was made on 900kHz and 9MHz on a Pye 39 JH/E coupled with a 10 turn loop on ouput and the 2m aerial wire draped around the loop. The Jack was fed with one channel of PC sound card. Audio level was a bit low without a 5:1 step up transformer. The Internal 400Hz did indeed look roughtly 30% on the 'scope.
The 300KHz to 900KHz band has  456 and 465 in small print on it.
It's important to allow about 10 minutes warm up time, you can use a cheap frequency counter to double check the frequency. The cheapest ones may not be sensitive enough below 2MHz as the output level is low. The Level is deliberately low to extremely low as it's specifically for testing Radio sets, not general purpose R&D / Test.
