1N2326 Diode Replacement, a Russian MP20 Transistor
17.Feb.18 05:53
2702
It has been well documented that a transistor can be used as diode In this graph, you can clearly see that a 1N2326 germanium diode has very similar characteristics in dropping voltage behavior when compared with a Russian MP20 germanium russian transistor
Red is is the 1N2326 Brown is the MP20 transistor (collector and base are tied together as the cathode
Attachments:- graph (31 KB)
