2N5156 Germanium Switching Transistor For Audio
? 2N5156 Germanium Switching Transistor For Audio
Can this transistor be used as a power transistor in and audio amplifier circuit?
Type Designator: 2N5156
Material of Transistor: Ge
Polarity: PNP
Maximum Collector Power Dissipation (Pc): 93 W
Maximum Collector-Base Voltage |Vcb|: 100 V
Maximum Collector-Emitter Voltage |Vce|: 60 V
Maximum Emitter-Base Voltage |Veb|: 60 V
Maximum Collector Current |Ic max|: 10 A
Max. Operating Junction Temperature (Tj): 100 °C
Transition Frequency (ft): 0.15 MHz
Forward Current Transfer Ratio (hFE), MIN: 25
Noise Figure, dB: -
Package: TO3
Yes, though it depends on the circuit. Push Pull would be best as then the bias currents cancel on the transformer.
A pair of these on a heatsink would be suitable to replace the 12V DC converter of the FT101 series. The FT101Z, FT101ZD etc has the windings on the transformer, but lacks the connector.
