An error to correct - tube 9GV8
20.May.26 02:54
25
Message to administrators - the tube 9GV8 should mention XLS85 as an equivalent, not with heater different.
Source: RCA data sheet; the tube displayed also shows both references printed on the glass.
Thank you!
20.May.26 07:34
25 von 1010
Articles: 1801
Hello Christian,
An European tube type XLS85 does not exist.
The letter S is not included in the European tube designation system.
The next closest European type to the 9GV8 is the XCL85, which has the same heater current 0.6 A, but a slightly different heater voltage of 8.6 V instead of the 9.5 V of the 9GV8.
The RCA specifications are incorrect.
Best Regards,
Jacob
20.May.26 16:33
61 von 1010
Hello Jacob,
My typo, sorry! Of course I meant XCL85.
In spite of slight variations in voltage specs / tolerances (according to manufacturers too), the two tubes XCL85 and 9GV8 are given equivalent by several manufacturers.
See attached pictures: RCA, Miniwatt, Sylvania
You can also see the many pictures of the tubes and the boxes on the radiomuseum site (e.g. the Dumont box with the XCL85)
Thank you!
21.May.26 07:02
100 von 1010
Articles: 1801
Hello Christian,
due to the slightly different heater voltage the 9GV8 and XCL85 are now linked as
“Normally replaceable-slightly different” to each other.
Jacob
