Métal, the IRIS brand and the Paris base
This article refers to the manufacturer: To the manufacturer
11.Jan.11 10:41
85
Métal used IRIS as an export brand. Next to each other you see a Métal 6/100 and IRIS type 6/100.
The French base (now called B4) is the oldest European base. But there is another early French 4 pin base, the so called Paris base. As for seize it is about as big as a bigrille base, missing one pin ofcours. Down below you will see a Métal type 6/100 with Paris base, the base itself and the Paris socket compared with a B4 socket.
Y base
14.Jan.11 21:26
85 from 3607
Hi Peter,
As french, I know this base as the Y base. First time I hear the "Paris base" name. Tubes with this base are very rare,
Christian
