saba: Saba Meersburg 7 Tape recorder input connector
This article refers to the model: Meersburg Automatic 7 (SABA; Villingen)
? saba: Saba Meersburg 7 Tape recorder input connector
29.Apr.23 07:42
32
Henry Saam (USA)
Articles: 8
Count of Thanks: 3
Hello,
I am looking for the name/type of the round connector in the back of this model for the Tape Recorder input (Tonbandgerät). It is a round connector with four equally spaced inputs at positions 12-3-6-9 o'clock and one larger hole in the middle. Also is this an input connector from tape player or output connector to tape recorder?
Thank you in advance for any pointers on how to connect audio to this input.
Best,
Henry
29.Apr.23 09:22
32 from 948
Daniel Consales (D)
Articles: 243
Count of Thanks: 4
Daniel Consales
Hello Mr. Saam,
actualy it is a "DIN Stecker, 3-pol". The 4th connection (at 6h) is an additional  ground connection for the shield.
I could only find a set (plug / socket) on amazon - search for "1 Paar 3-polig DIN Stecker + Buchse Audio"
It is both input and output ...
Kind regards,
D. Consales
29.Apr.23 09:54
38 from 948
Rolf Beckers (D)
Articles: 219
Count of Thanks: 1
Rolf Beckers
Dear Henry,
This is a German standard DIN 3pol connector. You may find it on Ebay, see attached PDF.
Regards,
Rolf
29.Apr.23 21:16
102 from 948
Henry Saam (USA)
Articles: 8
Count of Thanks: 2
Thank you very much Mr. Consales. This is very helpful.
Kind regards,
Henry Saam
29.Apr.23 21:19
104 from 948
Henry Saam (USA)
Articles: 8
Count of Thanks: 3
Dear Rolf,
Many thanks for your reply and the PDF file. This is very helpful.
Kind regards,
Henry
