Stereo Decoder
Stereo Decoder
28.Mar.06 05:59
Omer Suleimanagich (USA)
Articles: 422
Count of Thanks: 17
Omer Suleimanagich
Is anyone familiar with FM stereo on early sixties table radios that have the FM stereo decoder option?
Would this kit work on old table radios with the FM multiplex option?
http://www.kemo-electronic.com/en/bausaetze/b127/index.htm
28.Mar.06 07:45
Georg Beckmann (D)
Articles: 435
Count of Thanks: 9
Georg Beckmann
It's hard to judge, if this circuit is done right and works correct, because on the schematic there is no
information about the IC type.
I would say it would be a nice experiment and this could not be that expensive.
Probably, the input level of the mpx signal and the output level of the audio signal have to be watched.
Look that the coupling capacitors DC voltage are sufficient for the tube radio. To be save, please send
a schematic from the radio, how you would connect the decoder.
Georg Beckmann
28.Mar.06 07:55
Articles: 422
Count of Thanks: 5
Omer Suleimanagich
decoder information
29.Mar.06 08:21
Georg Beckmann (D)
Articles: 435
Count of Thanks: 13
Georg Beckmann
Hello,
I made a detailed doc how to connect the decoder, but had some problems with the upload, today, after work you'll get it.
Georg
29.Mar.06 09:05
Articles: 422
Count of Thanks: 6
Omer Suleimanagich
trouble with acrobat
29.Mar.06 21:59
Georg Beckmann (D)
Articles: 435
Count of Thanks: 5
Georg Beckmann
Hello Omer,
I was not able to make a pdf, because something is wrong with MS-word or the acrobat. So I sent a email to you directly. As soon as the problem is fixed, I try to load it up, that anyone can get it.
Georg
30.Mar.06 07:11
Articles: 422
Count of Thanks: 6
Omer Suleimanagich
Thanks for the detailed power supply instructions for the decoder.  I already have an external power supply that I intend to use for the Telefunken Concertino 5384W, but I definitely do intend to use this outline for future power supplies in other radios.
I was able to translate your attachment into JPEG via Irfanview, by copying and pasting from the word file.
Thank you for your help and i hope that others at RMorg can use this thread for a reference for stereo reception.
Again, many thanks,
Omer Attachments:
