10 Neon Tubes in a Lexan Block - What is it from??
? 10 Neon Tubes in a Lexan Block - What is it from??
07.Feb.18 17:09
84
Kevin Williams (USA)
Articles: 2
Count of Thanks: 18
Hello Everyone!
 I recently bought a large lot of tubes, and as usual, there are some items I have never seen before!  This one appears to be an set of 10 Neon indicator lamps, but the package it is in is very odd.  It seems to be a thick piece of lexan, or some similar plastic that has a ton of capacitors & resistors embedded.  It also appears to have never been installed, which makes sense as it was in a box of NOS parts.  Just wondering if anyone knows where this originated, I'm super curious.
Thanks!
-Kevin
08.Feb.18 16:20
84 from 1727
Michael Watterson (IRL)
Articles: 1120
Count of Thanks: 21
Part of an early 10 channel TV remote or touch panel? I remember touch panel TV numbers with neon illumination to show the channnel.
Even it's off something else, it's likely part of something like that. I suppose "Lexan" is American for Perspex?
09.Feb.18 14:42
168 from 1727
Articles: 2
Count of Thanks: 18
Hello,
 Thanks for the update, I suppose that it's likely this was from a TV.  It looked a little fancy for a radio, or at least a run of the mill radio.  Lexan is a brand name, and is a type of polycarbonate.  I guess that's what threw me a little.  The material seems too modern for the 1940 style parts in it.  I did a little more research and found that Lexan was invented around 1958, which seems a little too late for this piece.  However, other types of polycarbonate seem to have existed from the late 1920's.  It's likely just something I'm not familiar with.  It just has a "PCB" feel to, the way its designed.
Thanks!
-Kevin
Frequency counter?
09.Feb.18 21:54
198 from 1727
Steffen Thies (A)
Articles: 287
Count of Thanks: 18
This could be a display unit for a counting instrument. The small outline would allow to stack them to show a result. The way the components are assembled is called "Craigmount". The Beckman 7360A has such "ladder" counting units, bigger though with the tube circuitry attached. Its earlier versions also have the Craigmount assembly style.
09.Feb.18 22:01
203 from 1727
Articles: 1120
Count of Thanks: 17
The TVs I remember with neons behind the touch button channel numerals were UK Colour models in very late 1960s or maybe very early 1970s. Colour started between 1967 and 1969  in UK, depending on location and channel.
Frequency counter?
09.Feb.18 22:03
204 from 1727
Articles: 1120
Count of Thanks: 14
That could be, though the Dekatron (ten integrated pins sharing a central electrode) was more common?
09.Feb.18 22:05
205 from 1727
Articles: 1120
Count of Thanks: 22
The capacitors look more 1960s  than 1940s to me?
09.Feb.18 22:16
207 from 1727
Marc Gianella (CH)
Articles: 304
Count of Thanks: 17
Thanks for showing.
Why don't you draw the schematic? This would be interesting and helpful.
Regards, Marc
