6BH5A datasheet or specs
? 6BH5A datasheet or specs
08.Feb.23 10:20
47
Geoff Wheeler (AUS)
Articles: 6
Count of Thanks: 13
I am looking for data, pinout for 9-pin valve 6BH5A. I can only find reference to 6BH5.
I have one in an Australian radiogram that is unbranded.
The valve line-up is: 6AN7, 6BH5A, 6N8, 6M5, 6V4.
Thanks for any advice.
08.Feb.23 20:22
47 de 2723
Torbjörn Forsman (S)
Articles: 219
Count of Thanks: 10
For valve types of american origin and of that generation, differences between the basic version and the version with "A" suffix are usually almost negligible. Often the "A" denotes that the valve heater has controlled warm-up time so it safely can be used in series heating chains like in television sets. In other cases, the "A" means a later and slightly improved version that however is fully interchangeable with the basic version.
09.Feb.23 16:35
115 de 2723
Articles: 1801
Count of Thanks: 8
With exception of the base, the 6BH5 is electrically identical with type EF41.
For more data and curves see under EF41.
Best Regards,
Jacob
11.Feb.23 04:33
162 de 2723
Geoff Wheeler (AUS)
Articles: 6
Count of Thanks: 10
Thank you for this information. Very helpful. I can now fault-find the radio knowing that the pin configuration is correct.
11.Feb.23 04:34
162 de 2723
Geoff Wheeler (AUS)
Articles: 6
Count of Thanks: 12
Thanks for this information, knowing that the EF41 is an equivalent helps a lot with finding the fault on this radio.
