6E5 (6E5)
Moderadores:
Foro » Válvulas / Tubos - Semiconductores » TUBOS / SEMICONDUCTORES en RADIOMUSEUM » 6E5 (6E5)
Alessio Castagnini
Alessio Castagnini
I  Artículos: 76
Esquemas: 0
Fotos: 68
11.Nov.11 00:17
Agradecimientos totales: 12
Hello, is possible change a 6E5 with a 6E5C ?
Please, let me know!
Thanks a lot!
Bye
Michael Watterson
Redactor
IRL  Artículos: 967
Esquemas: 650
Fotos: 2496
11.Nov.11 10:32
Agradecimientos totales: 2
The normal 6E5 is 6 pin base and "bulb" shape.
The 6E5C is straight sided and octal base.
So if you change the tube socket or there is space for an octal to 6 pin adaptor (by moving the existing base which usually isn't on the chassis), then yes it should work. The pattern is the same and the sensitivity should be similar.
