AF3 (AF3)
Moderatoren:
Jacob Roschy Martin Renz Ernst Erb Bernhard Nagel Dietmar Rudolph Eilert Menke
Forum » Röhren und Halbleiter » RADIOROEHREN / HALBLEITER IM MUSEUM » AF3 (AF3)
Philip O'Shields
USA  Beiträge: 1
Schema: 7
Bilder: 57
24.Aug.09 01:12
What can I use as a more modern equivalent to a AF3?
D  Beiträge: 1706
Schema: 17
Bilder: 68
24.Aug.09 15:06
Hi Philip,
there is no direct modern equivalent, the AF3 was the end of the line.
However, you can use a 6K7 (-G, -GT) as substitute, by changing the socket and supply the 6.3 V heater voltage, probably by a small 4 to 6.3 V step-up auto-transformer or by some additional windings on the power transformer. As well you need to realign the surrounding tuned circuits.
A 78 may also work.
Best Regards, Jacob
Dieser Beitrag wurde am 24.Aug.09 15:08 von Jacob Roschy editiert.
