saba: Alignment question - Freiburg 9
This article refers to the model: Freiburg Automatic 9 (SABA; Villingen)
? saba: Alignment question - Freiburg 9
06.Apr.17 16:33
44
Here is my translation of the alignment instructions for the ratio detector:
Intermediate Frequency Adjustment 10.7 MHz 2-channel filter of the ratio-detector
- Disconnect the filter by turning K 601/603 to the left
- Primary channel, adjust L 601 at maximum
- Secondary channel set L 603 in the straight-line part of the curve with a zero-flow
This is clear enogh, but does K601/603 then have to be "connected" agin for maximum signal? Surely it canot be left "disconnected"?
Advice appreciated.
Martin
07.Apr.17 10:14
44 de 2603
Ok - I have now figured this one out too - there are errors in the guide.
Please see the red boxes on the attchment.
10.4MHz should of course be 10.7MHz
K501/503 should be K601/603.
Then it makes sense. I hope this helps others.
Martin
- Freiburg 9 alignment guide (269 KB)
