AM Single Frequency Network
26.Nov.09 10:16
7664
Articles: 2440
Count of Thanks: 20
Abstract
Single frequency networks (SFN) in the medium wave broadcast band were introduced in Germany in the late 20ies and early 30ies. They were developed by C. Lorenz A.G. So a short presentation of Lorenz transmitter development is given. A complicated problem then was the synchronization of these SFN. Therefore pilot tones of about 2 KHz were used and transmitted via telephone trunk lines. A frequency multiplication was necessary at the transmitter's side. Some solutions used a technique called today PLL. Between the SFN transmitters is a zone of heavy interference, where nonlinear distortion of the received AM signal occurs. Nowadays SFN's use digital modulations, and interference no longer plays a major role. Some principles of single and multi carrier radio systems are presented. In former days jamming transmissions on AM occurred. Optimal AM jammers use DSB modulation. In WW2 a jamming with intelligible text message was used. The modulation usable was SSB.
Original text in RM.org
German text .pdf file (97.2 KB) for automatic translation click here.
Regards
Dietmar
