arc-radio: 40B41M
arc-radio: 40B41M
20.Feb.13 03:49
23
John Allen (CDN)
Articles: 7
Count of Thanks: 7
John Allen
 This model is made by the Dominion Electrohome Industrys of Canada  and not the Arc Radio Corp ,of New York. When i added this model i couldnt find Dominion Electrohome in the data base at the time.
John Allen
Use the right procedures
20.Feb.13 14:00
23 von 2533
Emilio Ciardiello (I)
Articles: 527
Count of Thanks: 11
Emilio Ciardiello
Dear John,
Please use the right procedures to avoid generating confusion.
As far as I can see, you first loaded your photo to an already existing, but wrong model/manufacturer, then you loaded a Forum post to explain that the photo is related to a different manufacturers.
If you do not see the manufacturer of your set, you must select 'Create a new manufacturer', fill the form and then wait until administrators check the data you loaded and send you an email, approving the new manufacturer. After that, you must select 'Create a new model', entering all the known information on it, including the right manufacturer. When you receive an email, confirming the approval of the model, you can load your photo(s) to the right model/manufacturer.
Anyway, if you find something wrong in a model or in a manufacturer, the Forum is quite useless to correct wrong data. You must select the 'Data change' option from the 'Upload and Questions' menu and fill the wrong fields in the form with proper information.
The procedure may seem complex, but it is the one that has always been in use.
Best regards,
Emilio
