saba: bass pot issue
This article refers to the model: Freiburg-Automatic 3DS (SABA; Villingen)
? saba: bass pot issue
17.Nov.26 02:10
48
Troy Zoschke (USA)
I recently bought a SABA Freiburg Automatic 3DS that initially had no sound. After cleaning the piano-key switch contacts, I was able to receive FM. B+ is steady at approximately 260 V, and the components appear to be original.
The bass and treble controls were not working well, so I cleaned both. The sound is still muddy and poorly balanced. However, at one particular position near the middle of the bass control’s rotation, the volume increases by roughly 20%. It also seems clearer, although that may simply be the increase in volume. Cleaning the control a couple of times has made no difference.
There is also a spring contact on the rear of the bass control, which is unfamiliar to me since I have mostly worked on Grundigs. It does not appear to ride along a continuous contact track. The position where the volume increases is not where that spring contact closes.
I have not yet replaced the paper capacitors; that is my next step. Before proceeding, I would appreciate any thoughts on what might cause this behavior and what to check around the bass control.
