Braun (Chassis) RC61; TS2 output transformer wiring
Moderatoren:
Forum » Apparate: Physik - Radios - bis TV » MODELLE IM RADIOMUSEUM » Braun (Chassis) RC61; TS2 output transformer wiring
Marco Gilardetti
Marco Gilardetti
I  Beiträge: 149
Schema: 209
Bilder: 119
10.Mar.06 11:45
Antworten  |  Sie sind nicht eingeloggt (Gast).   1 Gentlemen, I have an output transformer of the Braun RC61 as a spare part, and I'm planning to use it in a home made project.   However, though I have the schematics, I'm having a hard time figuring out the wiring.
I see three thicker cables coming out of the transformer.   Plus,  there are other four very thin cables of different colors,  grouped in couple of two.
Can some owner of the radio please check which cable goes where?   I'm basically trying to use it as a simple output transformer:  tube output on one side,  a single 8 Ohm loudspeaker on the other.   I would need four connections,  but the transformer has seven.
Any help would be highly appreciated.   Thanks a lot.
Dieser Beitrag wurde am 10.Mar.06 11:46 von Marco Gilardetti editiert.
Arpad Roth † 27.3.17
A  Beiträge: 1024
Schema: 24449
Bilder: 1323
10.Mar.06 12:30
E-mail adress is okay.
Åke Holm <sm5cbw[A*T]telia.com> wrote:
> Hello
> can't reach the page, have forgotten my password
> Best regards
> Åke Holm
Marco Gilardetti
Marco Gilardetti
I  Beiträge: 149
Schema: 209
Bilder: 119
10.Mar.06 14:15
Antworten  |  Sie sind nicht eingeloggt (Gast).   3
Arpad, thanks a lot (I suppose your post went with my other thread, someone can move posts?).
As a matter of fact, that's not the address Ake put on his website. Will sure give it a try. Cheers - M.
Marco Gilardetti
Marco Gilardetti
I  Beiträge: 149
Schema: 209
Bilder: 119
23.Mar.06 12:39
Please note that the two last posts were off-topic, and the problem has not been solved yet. Will be very thankful to whoever will help!
Andre Bryx
Andre Bryx
D  Beiträge: 7
Schema: 0
Bilder: 4
13.Apr.06 11:08
Antworten  |  Sie sind nicht eingeloggt (Gast).   5
Hello Marco!
I have an open Chassis here ready for shipping could took a quick look.
If you have the shematics in front of you, the following is wired:
Thick Black: Output for the Bass Speaker
Thick Yellow: Output for the High Speakers over the 5uF capacitor
Thick Brown: Output Ground
Small Red: Goes to [+] of the rectifier
Small Yellow: Goes to W55 / 1.5K
Small Green: Goes to EL84 Anode / Pin 7
Small Black: Goes to W54 / 50K
But without warranty, it depends only on my own RC61 model!
Hope that helps..
Best regards,
Andre
