bush: BUSH DAC 10 dial lamp shunt
This article refers to the model: DAC10 (Bush Radio Ltd.; london)
? bush: BUSH DAC 10 dial lamp shunt
08.Dec.24 16:40
Reiner Scholz (D)
Articles: 247
Count of Thanks: 10
Reiner Scholz
Hello all, I am looking for help with my DAC10 serial number 62/51117
Service sheet 1002 is listing the dial lamp shunt  250 Ohm, 7 Watt.
My shunt  is marked 75 ohm, power ??, wire wounded and coated and looking original.
Measures 74 Ohm.  One bulb is burned out, one is ok. I assume having an older version and should
change it to 250 Ohm?
Regards   Reiner
08.Dec.24 17:54
15 from 787
Rolf Beckers (D)
Articles: 220
Count of Thanks: 6
Rolf Beckers
Hi Reiner,
I think the 75 Ohm is right, at least if the two dial lamps are 3,5 Volt each. If you consider a current of approx. 100mA the voltage drop is 7,5 V what is right for the two bulbs.
Regards Rolf
08.Dec.24 19:09
31 from 787
Reiner Scholz (D)
Articles: 247
Count of Thanks: 7
Reiner Scholz
Hi Rolf,
sounds logical. I am waiting for my lamps now and test again.
Thanks for help
Regards   Reiner
