CapaciTester CT355 Information Needed
This article refers to the model: CapaciTester CT355 (TeleTest Instrument Corp.; N.Y.)
? CapaciTester CT355 Information Needed
06.Jan.14 20:04
69
Bill Troyer (USA)
Articles: 2
Count of Thanks: 7
My capacitor tester is a CapaciTester CT355 mfg. by TeleTest Instrument Corp, NY.
Uses one 6AV6, and one 6AF6-G
I cannot find any info on this unit. There is no calibration on this unit.
Test modes seem to be; Dynamic Leakage, Capacity, and Continuity.
Tester is limited to caps rated at least 150 vdc.
Capacity is .00001 to 50uf.
It has a "5" Function Knob;
1. OFF
2. DYN LEAK & CONTINUITY
3. Capacity LO
4. Capacity M
5. Capacity HI
It has "2" Test Buttons forDYN LEAK & CONTINUITY: "TEST" & "REFERENCE"
I have figured out the leakage and the capacity tests, but not sure about the continuity and reference.
There does not seem to be any where to insert a reference cap unless you put it in the continuity position while placing th cap under test in the capacity position.
Any help with info would be greatly appreciated.
Please create the model
08.Jan.14 14:52
69 from 1983
Officer
Articles: 5745
Count of Thanks: 5
Hi Bill
I see that this is without an answer since two days. The main reason: Such questions have to come from a model page. I see that we have no model page for this instrument yet.
So I advise you to create the model by using the link "Create New Model" just over "L I N K S".
You have the manufacturer (brand), the model name, know what it is, what current it needs, the material, shape and even the tubes and measures.
You can already upload some photos to your proposal.
After the model is accepted by the model admins, you can use "my model" and for instance request a schematic. This comes in a list and there will be a red entry on the model page until a member loads a schematic.
Good is also that your forum entry shows some activity like uploading some pictures.
It seems that you have used your 1000 points by "look up's" or "downloads" which is the same for a server.
I wish you good luck.
