Capacitor identificiation markings
? Capacitor identificiation markings
25.Mar.13 22:10
David Schulman (USA)
Articles: 18
Count of Thanks: 9
David Schulman
I'm restoring a German set that I have and found what I believe to be an electrolytic cap that needs replacing. From what I can tell, it's 20uf @ 35 / 40 V. However, what I can't tell, is what the positive and negative leads are. They are marked 1 & 2. See attached photo. I'm not familiar with this designation, can anyone help? It is sincerely appreciated.
Bipolar or unipolar electrolytic
25.Mar.13 22:44
6 de 2539
Officer
Articles: 1680
Count of Thanks: 11
If both ends of the aluminium can have rubber insulators, it's a non polarized electrolytic. In this case, it is negligible how the electrolytic is soldered in place. Seems to be part of a speaker crossover network.
But i'm wondering if the stated capacitance of this specimen has been degraded. I would not replace this Siemens electrolytic if a) capacitance differs no more than -10% to +20% from printed value and b) the ESR (equivalent serie resistance) is low, about 1...5 Ω at 1 kHz. Usually these Siemens electrolytics are known for reliability although often more than 55 years old.
If replacement is still necessary, use also a non polarized elec. for audio applications (these have smooth electrodes for lower losses) or a plastic foil capacitor.
Thank you
25.Mar.13 22:52
8 de 2539
Articles: 18
Count of Thanks: 10
David Schulman
Bernhard, thank you so much. It is part of the audio network of a Grundig set. The bottom of the cap is seriously burned (something must have been extremely hot), so I think replacement will probably be necessary. I'll go ahead and test it just in case it can be saved.
Which Model?
26.Mar.13 10:54
60 de 2539
Officer
Articles: 1680
Count of Thanks: 9
Please specify the Grundig set (type/model), because this thread should be moved to it. Thanks.
Bipolar electrolytic
26.Mar.13 12:05
74 de 2539
Articles: 2319
Count of Thanks: 10
It is the capacitor 20µF from your Grundig 7063?
This is a bipolar type.
Type / Model
26.Mar.13 12:01
72 de 2539
Articles: 18
Count of Thanks: 9
David Schulman
It would be a Grundig 7063W/3D. And yes, that is the one. Thank you all for your help.
