Cossor 45IU
? Cossor 45IU
01.Jun.20 03:00
Ken Shellberg (USA)
Articles: 22
Count of Thanks: 18
I don't think this is a very rare tube. It turns up on eBay fairly often and I wonder why it isn't in RMorg?
It is the 4-volt version of the Cossor 53KU, which is in RMorg.
Cossor 45IU
01.Jun.20 08:40
12 from 2339
Articles: 1786
Count of Thanks: 16
Hello,
the page for the Cossor 45IU is now created, I hope, the comparison with the 53KU is correct.
Aside the heater voltage the base is different as well.
Best Regards,
Jacob
Cossor 45IU
01.Jun.20 14:55
42 from 2339
Ken Shellberg (USA)
Articles: 22
Count of Thanks: 12
I have both and the visible construction is identical. I should note that the skinny versions of the 53KU that some have posted are actually Mullard GZ37. Cossor ceased the production of vacuum tubes in the mid-1950's, but still made radios, so they simply sourced the GZ37 from Mullard and relabeled them.
And yes, the 53KU has an octal base and the 45IU has the European B-4 base, as one might expect for a British 4-volt rectiier.
Cossor 45IU
01.Jun.20 21:13
82 from 2339
Ken Shellberg (USA)
Articles: 22
Count of Thanks: 13
Hello Jacob,
I don't see a page for the 45iU that allows me to upload a picture? But I am very new here....
And unfortunately, I have not been able to find a data sheet for the 45KU. The British Valve Museum has some data on their site. And according to the document below (I have no idea where I found it or where it came from), the 45IU is equivalent to the MOV U18. This is all I can find...
Cossor 45IU
01.Jun.20 21:52
88 from 2339
Articles: 1786
Count of Thanks: 14
Hello Ken,
the page for the Cossor 45IU is still there.
The document on your photo shows a page out of the Tube (or Valve ?) Vademecum.
Jacob
Cossor 45IU
01.Jun.20 22:06
90 from 2339
Ken Shellberg (USA)
Articles: 22
Count of Thanks: 15
Hello Jacob,
Thank you for pointing me the 45IU page. When I use the search function on the home page, this page doesn't show up. Again, I'm very new here, so perhaps there is a better way to search?
Thanks again,
Ken
Cossor 45IU
01.Jun.20 22:34
98 from 2339
Articles: 1786
Count of Thanks: 16
Ken,
to search a tube type, (1) first click on the tab “Tubes + Tr”, (2) then type in your desired tube,
(3) probably you can chose a search condition.
Jacob
Cossor 45IU
01.Jun.20 22:36
98 from 2339
Ken Shellberg (USA)
Articles: 22
Count of Thanks: 17
