shenzhen-d: DEGEN DE1105 - Component details
01.Aug.23 11:15
83
Jose Mesquita (P)
Articles: 111
Count of Thanks: 2
Jose Mesquita
The Degen DE1105 design uses double heterodyne conversion on AM bands (MW and SW) and single conversion on FM band. The IF are:
  • FM: 10.7 MHz
  • AM 1st IF: 28.000 MHz
  • AM 2nd IF: 450 kHz
The AM 1st IF is therefore above the upper SW band limit of 26.100 MHz.
The radio uses two PCB assemblies:
  • MCU PCB.
    • So far only one PCB version is known
      • DE1105S-1  REV.0.10  2005.07.04
    • At least two MCU Processor versions exist
      • DE11S-MCU  2007.05.14
      • DE11S-MCU  2009.05.27
  • Receiver PCB
    • So far only one version is known
      •  DE1105M-2  DEGEN  0120
The built-in speaker is a 12Ω 0.25W unit.
The two PCB assemblies are interconnect with a flexible flat cable. The silkscreen labels for each pin at the connector are:
  1.     vol
  2.     mute
  3.     ce
  4.     al
  5.     vcc
  6.     power
  7.     gnd
  8.     gnd
  9.     do
  10.     bass
  11.     st
  12.     clk
  13.     di
  14.     pwm
  15.     aga
  16.     agc
  17.     i/out
  18.     i/out
  19.     batt (+)
  20.     batt (+)
The following component listings only cover the main devices.
Receiver PCB Ref. DE1105M-2 DEGEN 0120
Component side:
U3    TA7358AP  -   FM front-end
U4    65N4    -  LDO Regulator, SOT-23-5 5-PIN IC SMD
Q9    K544E (2SK544E)    -    N-MOSFET VHF, Idss=2.5..6.0mA
Q17, Q27    YJ7 (2SK2394-7)   -     N-FET LN, HF, Idss=16..32mA, SOT-23
CF6   XTAL 27.550 MHz   -    Local 1st Oscillator for U2-AM_OSC
CF7   XTAL 28.000 MHz   -     AM 1st IF filter
CF3   CQ ZTB 456F16     -     456 kHz FILTER for U2-VCO
CF4   L10.7S    -   10.7 MHz FILTER
CF2   L10.7S    -   10.7 MHz FILTER
CF5   CQ R50I  -   450 kHz 4+1 PIN FILTER for U2-AM_IF_IN
Less Components side:
IC1    CD1622CB (EQ CXA1622M)  - Stereo power amplifier / mono BTL power amplifier;
U1     LC72122   -      PLL Frequency Synthesizer 20-pin smd
CF1   XTAL         -      U1 Osc
U2     TA8132AF   -    3V AM / FM IF + MPX
MCU PCB  Ref. DE1105S-1 REV.0.10 2005.07.04
Component side partially covered with metal shield:
U101    DE11S-MCU 2007.05.14  -  MCU Processor
U102    N14B           -  3-PIN SOT-23 SMD Voltage detector IC 1.4V, - Reset
U103    ATMLH736  -  SOP-8 SOIC-8 Atmel 2048 x 8 (16K) SPI  EEPROM, 1.8v TO 5v,
U104    65P 0 (also seen as 2C0)   - 5-PIN SOT-25 SMD LDO regulator 2.2V, 300mA XC62H series
Q101    NY               -  SOT-89 PNP power switching 2SA1213?  50v 2a 500mW
Q102    J6       -  SOT-23 NPN general purpose switching
Q103    J6       -  SOT-23 NPN general purpose switching
Q105    J6       -  SOT-23 NPN general purpose switching
Q106    M6      -  SOT-23 PNP general purpose switching
Q107    J6       -  SOT-23 NPN general purpose switching
D100    C3       -  SOT-323 dual fast switching diodes
D101    C3       -  SOT-323 dual fast switching diodes
Display/KB Side:
D117    LED display
D115    LED display
D120    LED keyboard
D119    LED keyboard
D118    LED keyboard
Note on schematic diagrams:
I could not find any complete circuit diagrams for this model. However the DEGEN DE1102 diagram is available for download and, while having different specifications namely a lower 10.7MHz 1st AM IF frequency (28MHz on the DE1105) or a manual Local/DX attenuator (Automatic attenuation adjust at the antenna input - AGA command) or a different PLL IC, is close enough to be used on the DE1105.
02.Aug.23 12:38
83 von 1170
Michael Watterson (IRL)
Articles: 1124
Count of Thanks: 3
The 28 MHz seems a strange choice of first IF unless someone had huge load of very cheap 27.550 MHz crystals.
At the least I'd have chosen a European audio, Nicam or video IF frequency (32 to 39 MHz band). I think later USA sets used 40 MHz band.
But also maybe the main target market only allowed up to 26.10 MHz. CB bands are roughly 26.5 Mhz to 28 MHz (depending on country and era) and 10M Amateur is 28 MHz to 29.7MHz. A 10.7 MHz first IF for dual conversion on AM on an AM-FM set was a simple cost saving solution. Some earlier Sangean sets use about 56 MHz to 58 MHz depending on market, which seems curious compared to a 30MHz band 1st IF such as 33.5 MHz.
Thanks for the analysis.
