EM34 function
EM34 function
25.Oct.06 23:37
Philip Navarrete (USA)
Articles: 13
Count of Thanks: 9
Just what is the EM34 Eye supposed to do? My EM34 does not give the eye indication at all in FM. It's dark and blank. From what I remember the eye is supposed to open and close as stations are changed. Could I have a bad EM34?
Philip Navarrete
Thread moved to tube
eye tube function
26.Oct.06 00:28
Thomas Albrecht (USA)
Officer
Articles: 378
Count of Thanks: 15
Thomas Albrecht
Philip,
The EM34 is a dual-action eye tube.  It should glow brightly, with a dark wedge at both the top and bottom of the face.  One of the two wedges is more sensitive than the other.  For example, on a weak station, only the more sensitive wedge changes width.  On a very strong station, the sensitive wedge is saturated, and the less sensitive shows some width change.
If the tube doesn't glow at all, check the plate and grid voltages to make sure there isn't a problem in the surrounding circuitry.  Unfortunately, it is not uncommon to find very dark or completely dark eye tubes.  Most used ones have low emission.  The lifetime of these tubes is only 1000 hours or so.  If the radio was used frequently, the eye tube could easily have worn out in the past.  Since the radio still functions fine without a working eye tube, many radio owners never bothered to replace the eye tube.
Best regards,
Tom
EM34
26.Oct.06 13:59
Articles: 13
Count of Thanks: 15
