Freed Eismann NR-5 Bad grid leak?
        This article refers to the model: NR-5 (Freed-Eisemann Radio Corp.; New York, NY)
      ? Freed Eismann NR-5 Bad grid leak?
          09.Aug.09 23:21
         I have a Freed Eismann NR-5 that does not play. I checked the grid-leak cap and it showed up at 120K. Is this correct? The resistor checks at a steady 2 meg.
Thanks.
Please post only from the model side. I scrolled your thread to the model.
bad !
          10.Aug.09 19:10
         Well, that cap is sure gone.
           Verify by (makeshift) replacement with 100 to 200 pF (µµF).
Good luck!
