grundig: Grundig Stereo system
? grundig: Grundig Stereo system
22.Oct.21 18:49
96
Scott Monroe (USA)
Articles: 2
Count of Thanks: 5
Does anyone have a schematic for the AM/FM shortwave, Grundig radio installed in the KS712U model? Also looking for information on the turntable.
24.Oct.21 18:12
96 de 2290
Articles: 2327
Count of Thanks: 17
Hello Mr Monroe,
Your model is very likely to have the HF45U chassis installed.
Please first start a circuit diagram search from the model page
Model page ==> My model ==> I need this schematic.
Your model has the equipment:
ECC85 or 6AQ8, ECH81 or 6AJ8, EAF801, ECC83 or 12AX7, EM87 or 6HU6, ECLL800, ECLL800.
However, since it sometimes takes a long time before the circuit diagram you are looking for is uploaded and you need the diagram immediately,
You can find a very similar diagram in the model: Stereo Console KS650U Ch= HF45U - Grundig.
The completely identical radio chassis can be found in the Stereo Console Locarno 1/U Ch= HF45U.
Unfortunately, the circuit diagram there is of very poor quality.
With the model Stereo Console KS620U Ch= HF45U, unfortunately, the plan is of a model with the chassis HF45 with MW, LW, SW, FM.
The HF45U chassis has MW, 2 x SW and FM.
I hope this helps you further.
With best regards WB.
27.Oct.21 19:21
222 de 2290
Scott Monroe (USA)
Articles: 2
Count of Thanks: 4
I would like to find information on the dial cord and its installation. The shortwave portion is seized and the AM/FM has broken cord. Please send any if you have it. Thanks for your help.
28.Oct.21 10:11
266 de 2290
Articles: 2327
Count of Thanks: 4
Hello Mr. Monroe,
Here is the plan for the cable pull.
You can also find this as the 4th plan with the model Stereo Console KS620U Ch= HF45U.
