hammarl-mf: Hammarlund SP-600 - Variants
29.May.15 23:36
70
Martin Bösch (CH)
Articles: 612
Count of Thanks: 14
Martin Bösch
The SP-600 has been produced in very many variants over the years. An eccellent review of all types is found in the book "Shortwave Receivers Past & Present" by Fred Osterman, the original version of Les Locklear's listing under www hammarlund.info.
The typeplate is usually found on the cover of the r.f. unit:
  • J will say that all components meet the JAN (Joint Army Navy) Standard requirements
  • an X means that the receiver is equipped with an oscillator for crystal controlled fixed frequency operation, and
  • a L, that the set covers not the mediumwave band but the longwaves, used in the United States for aeronautical beacons (NDB).
SP-600-JX-1 Frequency range 540 kHz - 54 MHz,
Army designation R-274A/FRR, Contract 1689-Phila-51-01
Part of sets AN/MRR-4; GRC-38A & B
SP-600-JLX-2 Frequency range 100-400 kHz & 1,35-29,7 MHz
SP-600-J-3 Frequency range 540 kHz - 54 MHz,
no crystal controlled fixed frequency operation
SP-600-J-4 Frequency range 540 kHz - 54 MHz,
no crystal controlled fixed frequency operation, separate i.f. amplification control
Army designation R-320A/FRC, contract 19474-Phila-50-06
part of set OA-58B/FRC
type C
SP-600-J-5 Frequency range 540 kHz - 54 MHz,
no crystal controlled fixed frequency operation, powered AC 25 - 60 Hz
Army designation R-483/FRR, contract 21478-Phila-50
SP-600-JX-6 Frequency range 540 kHz - 54 MHz,
BFO-Bereich +/- 10 kHz
Navy designation R-274B/FRR
SP-600-JX-7 Frequency range 540 kHz - 54 MHz
SP-600-JX-8 Frequency range 540 kHz - 54 MHz,
produced for Welch Contract XG-479
SP-600-JL-9 Frequency range 100-400 kHz & 1,35-29,7 MHz
SP-600-JX-10 Frequency range 540 kHz - 54 MHz
Successor of the SP-600-JX-7
SP-600-J-11 Frequency range 540 kHz - 54 MHz,
Successor of the SP-600-J-3
SP-600-JX-12 Frequency range 540 kHz - 54 MHz,
Signal Corps designation R-274A/FRR, contract 3376-Phila-52
Successor of the SP-600-JX-1
type B
SP-600-J-13 Frequency range 540 kHz - 54 MHz,
no crystal controlled fixed frequency operation, powered AC 25 - 60 Hz,
contract 16838-Phila-51, Successor of the SP-600-J-5
SP-600-JX-14 Frequency range 540 kHz - 54 MHz
Signal Corps Bezeichnung R-274C/FRR (R-542/FRR), contract 3376-Phila-52
Successor of the SP-600-JX-10
type B
SP-600-JLX-15 Frequency range 100-400 kHz & 1,35-29,7 MHz
Successor of the SP-600-JLX-2
SP-600-JL-16 Frequency range 100-400 kHz & 1,35-29,7 MHz
Successor of the SP-600-JL-9
SP-600-JX-17 Frequency range 540 kHz - 54 MHz
Diversity receiver, can be identified by the two red metal knobs,
produziert for the Air Material Command
type D
SP-600-JX-18 Frequency range 540 kHz - 54 MHz
Produced for GAUVREAU contract.
SP-600-J-19 Frequency range 540 kHz - 54 MHz,
Successor of the SP-600-J-13
SP-600-J-20 Frequency range 540 kHz - 54 MHz,
no crystal controlled fixed frequency operation, powered AC 25 - 60 Hz, 90 - 270 V
Signal Corps designation R-483A/FRR, contract 3479-Phila-52-05
Successor of the SP-600-J-19
type A
SP-600-JX-21 Frequency range 540 kHz - 54 MHz
Successor of the SP-600-JX-10 & SP-600-JX-14
SP-600-J-22 Frequency range 540 kHz - 54 MHz,
Successor of the SP-600-J-11
SP-600-JLX-23 Frequency range 100-400 kHz & 1,35-29,7 MHz
Successor of the SP-600-JLX-15
SP-600-JL-24 Frequency range 100-400 kHz & 1,35-29,7 MHz
Successor of the SP-600-JL-16
SP-600-J-25 Frequency range 540 kHz - 54 MHz,
SP-600-JX-26 Frequency range 540 kHz - 54 MHz
Signal Corps Bezeichnung R-274C/FRR, contract 3376-Phila-52
Successor of the SP-600-JX-14 & SP-600-JX-21
SP-600-JLX-27 Frequency range 200-400 kHz & 540 kHz - 29,7 MHz
SP-600-JX-28 Frequency range 540 kHz - 54 MHz
Signal Corps designation R-620/FRR, contract 25693-Phila-53-61
SP-600-JX-29 Frequency range 540 kHz - 54 MHz
produced for CIA, Contract No. XG-1178
SP-600-JX-30 Frequency range 540 kHz - 54 MHz
Diversity Empfänger, can be recognized by the two red metal knobs,
Successor of the SP-600-JX-17
SP-600-VLF-31 VLF frequencies 10 - 540 kHz
4 crystal controlled fixed frequencies
SP-600-JX-32 Frequency range 540 kHz - 54 MHz
black frontpanel with engraved lettering
produced for Mackay Radio, technically identical to the SP-600-JX-21
SP-600-JLX-33 Frequency range 100-400 kHz & 1,35 - 29,7 MHz
SP-600-JL-34 Frequency range 100 - 200 kHz, 540 KHz - 14,8 MHz
for CIA, Contract No. XG-1765
SP-600-JX-35 Frequency range 540 kHz - 54 MHz
Signal Corps designation R-274B/FRR
SP-600-JX-36 Frequency range 540 kHz - 54 MHz
technically identical to the SP-600-JX-21, additional audio input at the rear
produced for the FBI under contract No. FBI-16876
SP-600-JL-24 "Special" Frequency range 100 - 200 kHz, 1,35 - 29,7 MHz
US Navy designation R-274B/FRR
SP-600-JX-37 Frequency range 540 kHz - 54 MHz
Successor of the SP-600-JX-21
SP-600-VLF-38 VLF frequencies 10 - 540 kHz
SP-600-JX-39 Frequency range 540 kHz - 54 MHz
produced for FAA Contract FA-2338
SP-600-JX-21A Frequency range 540 kHz - 54 MHz
Latest variant of the SP-600 with product detector (LSB/USB/CW MOD switch)
Frontpanel with engraved lettering and designation JX-21A
Please take care of adding your images to the correct model, thank you
Martin Boesch
30.May.15 20:42
70 from 4608
Martin Bösch (CH)
Articles: 612
Count of Thanks: 17
Martin Bösch
Here find the four main types of front panel design, this might be helpful to distinguish between different variants, if you only have access to images and cannot open the set to check the typeplate inside in the receiver:
Type A (R-483/FRR) Type B (R-274A/FRR and R-274C/FRR)
Type A Type B
No fixed frequency control in right upper corner Controls to select fixed frequencies in right upper corner
Type C (R-320A/FRR) Type D (SP-600-JX-17)
Type C Type D
IF gain control in right upper corner, no fixed frequencies The model designed for Air Material Command comes with red knobs and is prepared for diversity operation
